activation Codes
activation Codes
activation Codes
We have 30 machines that will be reimaged as we move from 32 bit to 64 bit operating systems. Is there an easy way to do this.??
I called in 4 times today and still cant get an email with an acivation code for the one I am working on now. I tried doing it on line and it thinks I have gone over my 30 licenses.  Thanks Dawn
Otto
Hello dtichenor and welcome to the Autodesk community!
If you’re having trouble with the activation email, please note that sometimes the email can be accidentally routed to your spam or junk folder. Please check there.
Also, please note that you should be able to access your download and activation information by logging into Autodesk Accounts.
If you cannot access software in your account and need to download it now, please go to the Virtual Agent.
If none of those items helped, please submit a support request as follows:
Students should request to have the confirmation email resent via this form.
If you are having trouble with your Autodesk Account or an eStore purchase, please visit our order support page where you will be able to chat with a representative or submit a support request.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
TravisNave
Imaging stand-alone licenses is generally problematic.  It's almost best just to create a deployment and install them all afterwards and let them activate properly.  Otherwise, you will simply have to get manual activations for each one and they may or may not work.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
I get that. But in this case this one crashed . So when I try to put the Request code in that I was given it says it cant give me an activation code because we
are over our licensing which is not the case. This has been a frustration from day 1 with this program and we have two schools involved with the PLTW program 60 computers total. This is not an optimal way to do business. Thanks Dawn
TravisNave
Yikes. The optimal way would have been for somebody to have recommended
that you network activate all of those seats. Almost nobody has that many
stand-alones. Network seats do not have this unfortunate limitation. You
have a lot of manual work ahead of you because the automated system will
not work for you.
Autodesk Forums:
