Installer Runs To 99%, Creates Desktop Shortcut then immediatelly throws an error with no code.
Log File Attached Below
Exactly the same issue here: https://forums.autodesk.com/t5/fusion-francais/fusion-probleme-d-installation/m-p/12683627#M11011
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
Hi @minartomas70 , it looks like you may be using old installer. Can you please use the suggestion as in forum post:- https://forums.autodesk.com/t5/fusion-support/problem-installing-fusion-360/m-p/12689490 as it helps to resolve the problem.
Regards
Sikandar
