Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Problem Installing Fusion 360
2 REPLIES 2
minartomas70
162 Views, 2 Replies
Installer Runs To 99%, Creates Desktop Shortcut then immediatelly throws an error with no code.
Log File Attached Below
2 REPLIES 2
JeromeBriot
in reply to: minartomas70
Hi @minartomas70 , it looks like you may be using old installer. Can you please use the suggestion as in forum post:- https://forums.autodesk.com/t5/fusion-support/problem-installing-fusion-360/m-p/12689490 as it helps to resolve the problem.
Regards
Sikandar
Technology Administrators
