Modify Drawer STL
Modify Drawer STL
3D_Ken
Message 1 of 66
Modify Drawer STL
3D_Ken
I have an STL file of a drawer that I need to modify to make the drawer deeper while keeping the top part unchanged.  It is my understanding that the first step is to import the STL as a mesh.  I have done this, but I don't know what the next step is.  My only thought is converting the mesh into a body, slicing the body in two, separating the two sections and finding a way to fill in the space.  Is this what I should do, or is there a better way?
STL and F3D attached.
Replies (65)
Message 61 of 66
TheCADWhisperer
@3D_Ken
If you turn off the visibility of the upper handle, what do you observe?
Edit: Besides this issue, I observed at least two other issues in your file.
Message 62 of 66
3D_Ken
"If you turn off the visibility of the upper handle, what do you observe?"
I observe that it is wrong, but I don't know why or how to fix it.
It may be in the shell command, which I had a lot of trouble with.  I'll play with again, but I don't have much hope in getting it right.
Message 63 of 66
TheCADWhisperer
@3D_Ken
That is not what I observe, but I have a couple of other projects to complete till I will have time to get back to this one.
Check back.
Message 64 of 66
TheCADWhisperer
@3D_Ken
I already posted a file with your sketches cleaned up - I recommend that you start over from scratch (that is exactly what I did for you).
Message 65 of 66
TheCADWhisperer
@3D_Ken
I observe:
Fully defined sketches.
No user created Workplanes
A hole after hiding the Handle-Upper...
Logically, I would cut a hole for the Handle-Lower...
Message 66 of 66
3D_Ken
I think I have a final version.  I got rid of the blue lines, and the extra delete on the back cutout.  I added a cutout on the back wall which I need for one of my drawers, but not the other.
I tried getting rid of the line across the top which you commented on, but nothing I did seemed to make it go away, even starting over with your base sketches.  In that it seems to be doing no harm, I am choosing to ignore it.
I GREATLY appreciate all your help on this project and I have learned many things along the way.  It is possible that I could have done this on my own using brute force and numerous extra hours, but it would not have come out as well and would not have been as customizable.  I think the best things I have learned along the way are Project and Shell.  I will surely be using them quite a bit in the future.
Attached is the version I intend to print.
