The 2D-drawings workspace could use some improvements.
- Add weld symbols.
- Edit balloon content.
- Attach text to balloons, dimensions and "control frames".
- Breaks on leaders.
- Dash-dot-line for section view call-outs.
- Put balloons anywhere.
- Add possibility to select horizontal text direction for diameter and radius.
- Attach "control frames" to dimensions, make them follow movement of the dimension.
- Free-standing machining/surface roughness symbol for general requirement.
- Correct the diameter symbol in the "control frame".
- Create custom paper dimension (at least add A3 portrait).
- Ability to set default view line visibility (I do not like "hidden lines", so every time I make a new view I have to change, very annoying). Same with tangent edges.
- I am using a PDM system which creates the drawing frames, I want to be able to set a preference to have the default as no frame and no border on new drawing creation.
![After.png After.png](https://forums.autodesk.com/t5/image/serverpage/image-id/609244i02B013E453390291/image-size/large?v=v2&px=999)
