2D Drawings need more options for dimensions
Actually I did not find any option to set the blue dimension.
There is no option to set help-lines in 2D-Drawings like the red one in the pic.
Many saws need the blue dimension angle.
Please vote for this simple function.
Thanks.
1 Comment
dan_goodrich89
That dimension you are trying to produce doesn't actually exist in the real world as you cannot measure it to check once it has been made. You measure the acute and obtuse angle based on faces that exist.
You can produce this line by adding an additional sketch in the model, and turning the sketch on in the drawing. This should be denoted as a Reference dimension (using brackets) as you could have over dimensioned the component, and you are dimensioning off of faces that do not exist.
