2D Drawings in Fusion 360 may seem outdated but they remain a vital way of communicating manufacturing details to production engineers. Fusion 360 cannot be taken seriously as a comprehensive design tool without the following features.
- Local sections are vital - not currently supported.
- Chain lines between thickened ends of section lines to BS8888; currently the only way to achieve this is to select a section line which coincides with a mid point, place a centre-line and extend it manually.
- We need a way of drawing in additional lines.
- Line weight control
- Line type control
- Closer control over hatching of components; the software often trips up and accidentally hatches a neighbouring component, shaft or fastening.
- A view cube, within the drawing environment, (as in Inventor) to orientate the views as they are placed instead of relying on the original orientation of the assembly or component in the part file.
Many thanks, Andrew.
