Revit 2023: Revit Walls - An Alternative Approach to Design and Creation Series 3 of 6
Method 3 – Walls as Railings
  • This method is meant to use walls and custom families nested in the walls to act as a railing system.  Sometimes working with the Railing command isn’t so intuitive so when you want a quick, down and dirty way of making a low wall with “balusters,” use this method.  The key thing to remember in this method is that you are inserting a “baluster” custom family (wall based family) that has an Opening object within the family to cut the host wall (similar to a door or window inserted into a wall).
Pro Tip:  Use different low wall types (glass, block, metal, etc.) and different custom “baluster” families to make interesting railing design.
