i pressed a command which made my file quit and then accidentally pressed no when it said to save changed how to recover my file?
husman1
Message 1 of 9
husman1
please help im on a uni computer so i cant rename filed to dwg. when i go on the file none of my work i did for the past hours is there, is there anyway to recover it please
Replies (8)
Message 2 of 9
RSomppi
If the changes were not saved and you exited AutoCAD cleanly, the work is gone.
Message 3 of 9
husman1
i managed to recover it!!!
Message 4 of 9
RSomppi
Explain how you did it and mark your response as the solution!
Message 5 of 9
husman1
i went into the temp folder and found a bunch of bak files and changed them to dwg and the last one i tried came up with the unsaved work
Message 6 of 9
RSomppi
If it was a .bak, file then you saved your work more than once.
Message 7 of 9
mkurti
Community Visitor
Community Visitor
my work didn't save when autocad had an error so it kicked me out
Message 8 of 9
CAD162K3TU
Community Visitor
Community Visitor
I also lost everything! I forgot to save it and I lost my hours work and I really need it back fast
Message 9 of 9
pendean
Community Legend
Community Legend
Do this
https://forums.autodesk.com/t5/autocad-forum/i-pressed-a-command-which-made-my-file-quit-and-then/td...
After that, try all of these tips
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/how-to-recover-los...
After that, sorry, you are out of luck unless your I.T. person can help you find options.
