AutoCAD Forum
i pressed a command which made my file quit and then accidentally pressed no when it said to save changed how to recover my file?
6 REPLIES 6
husman1
711 Views, 6 Replies
please help im on a uni computer so i cant rename filed to dwg. when i go on the file none of my work i did for the past hours is there, is there anyway to recover it please
6 REPLIES 6
RSomppi
in reply to: husman1
If the changes were not saved and you exited AutoCAD cleanly, the work is gone.
husman1
in reply to: RSomppi
i managed to recover it!!!
RSomppi
Explain how you did it and mark your response as the solution!
husman1
i went into the temp folder and found a bunch of bak files and changed them to dwg and the last one i tried came up with the unsaved work
RSomppi
If it was a .bak, file then you saved your work more than once.
mkurti
my work didn't save when autocad had an error so it kicked me out
Forma Design Contest
AutoCAD Beta
