Multileader block with attached attribute annotation
1wildwes
1wildwes
Is there a way to create Multileaders with attached attributes such as in the attached? The attached shows a Multileader with a circle and leader and also Mtext with a line.  I'd like to have all in a block where you can edit the Multileader anno, the external anno and the line will extend or shorten in relation to the text.
pendean
Community Legend
Community Legend
This would be a block of yours, all of it (what you need to behave like "mtext" can be a Multi-Line Attribute instead)
You would add that block here in MLEADERSTYLES command
No, you cannot slip in a block inside the MTEXT editor (which is also used in MLEADER). Sorry. That's not a thing in AutoCAD to date.
HTH
