please help im on a uni computer so i cant rename filed to dwg. when i go on the file none of my work i did for the past hours is there, is there anyway to recover it please
Solved by husman1. Go to Solution.
Solved by RSomppi. Go to Solution.
i went into the temp folder and found a bunch of bak files and changed them to dwg and the last one i tried came up with the unsaved work
