AutoCAD Forum
How to adjust mouse speed ?
18 REPLIES 18
Message 1 of 19
46137 Views, 18 Replies
How do you adjust the mouse speed while in the drawing area ? The mouse speed is going too fast.
18 REPLIES 18
Message 2 of 19
Emmsleys
Hello @Anonymous,
Try adjusting the ZOOMFACTOR system variable. You can modify this system variable from 3 - 100 the default is 60.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists
Sarah Emmsley
Technical Support Specialist
Message 3 of 19
Emmsleys
@Anonymous
As a test you could also adjust the following system variables to see if any of these system variables help fix the issue;
SELECTIONCYCLING = 0
UCSDETECT = 0
ORTHOMODE = 0
DYNMODE = 0
ROLLOVERTIPS = 0
SAVEFIDELITY = 0
QPMODE = 0
SNAPMODE = 0
SELECTIONPREVIEW = 0
PROPERTYPREVIEW = 0
Sarah Emmsley
Message 4 of 19
nrz13
The mouse speed is a Windows property.  Go to Control Panel → Mouse → Select Pointer Options tab → Adjust Motion pointer speed → Click OK.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 5 of 19
pendean
in reply to: nrz13
... the correct answer 🙂
Message 6 of 19
in reply to: nrz13
Yeah that works sometimes, but not in this instance. I am also having the same issues, my mouse's sensitivity is fine everywhere but in the drawing space. the toolbars, the desktop, other applications and software its fine. in the drawing space in ACAD Arch, insanely sensitive. some of the other ideas in here seem to have made it somewhat more bearable, but still not correct. this is an insanely annoying side effect that has inhibited my productivity immensely.
Message 7 of 19
nrz13
@Anonymous
Just curious, do you have a double-resolution / Retina display where the pixel count is doubled in the same area from a traditional display (e.g. a 3840x2160 resolution appears as 1920x1080)?  AutoCAD has had a lot of problems with those displays in the past, although from what I understand the newer releases supposedly address many of those issues.
It certainly seems like that is what's going on.  AutoCAD thinks the resolution in the drawing area is double what you actually see, meaning the cursor would move twice as fast.
Message 8 of 19
in reply to: nrz13
Do you know of any fix for this?
I'm having the same issue and what you're telling seems to be correct.
I'm running Autocad in Parallels on Mac, so I probably have 2 resolutions.
Message 9 of 19
nrz13
@Anonymous
Ordinarily, I'd say to keep playing with your display settings – resolution and scaling.  The closer to native resolution and 100% scaling you can get, probably the better (which will make things tinier).  In your case, running it in a virtual machine, I'm not sure how that would play out but it might still be worth trying.  I wonder if the cursor problems might be due to glitches between AutoCAD and Parallels as well.  If you run Windows natively via Boot Camp, you'll still likely encounter some resolution issues (although Autodesk has supposedly fixed many of these in recent versions), but that may solve your cursor movement issue, at least.
Message 10 of 19
in reply to: nrz13
So it turned out being a problem with the remote connection, and i believe it was because of the resolution. I was running at one resolution on my desktop at work and a different one at home on my laptop/monitor. Sorry it took me so long to respond and thank you for the information.
Message 11 of 19
johnwilfredbecker
Enter "3dconfiq" hit enter, turn hardware acceleration to off. Link below:
https://youtu.be/k89m0B1zvAk
Message 12 of 19
 After trying a few things, finally what worked for me to stop the slow lagging and just the slow mouse inside of the work area was to turn off the hardware acceleration.
Go to:
A > Options > system > Graphics performance > Turn off Hardware Acceleration> OK.
And immediately you should notice a difference.
Message 13 of 19
in reply to: johnwilfredbecker
Thank you very much!
After a fresh install, I had a slow mouse in the workspace.
"3DCONFIG" / Hardware Acceleration / Off. worked for me!
Message 14 of 19
sndbbbl
I am using AutoDesk TRUEVIEW. TRUEVIEW cannot use the command line - so no possibility to enter the command "3dconfiq".
I could access the GRAPHICS PERFORMANCE -> EFFECT SETTINGS -> HARDEWARE ACCELERATION [ON]
I turned off this HARDWARE ACCELERATION, but no change in mouse speed...
My mouse (specifically the HOUSE WHEEL for zooming) is far to sensitive inside the AutoDesk TRUEVIEW window... it behaves normally in rest of Windows though....
Any help is highly appreciated.
Message 15 of 19
in reply to: sndbbbl
The problem for me ended up being differences in screen resolution between my laptop and the computer I was remoting into.
Message 16 of 19
That works thank you. Alternatively, you can run command GFXDX12 and set the value to 0.
Message 17 of 19
pendean
in reply to: ocasaenva
@ocasaenva Do you just need to turn off SNAP (F9 key on your keyboard toggles it on/off)?
Or does your mouse have a dedicated driver that you need to review in detail to change something there?
Message 18 of 19
soli_zo_f_or_m
To adjust your mouse speed in Windows, you can follow these steps: Windows Settings: Click on the "Start" button (Windows icon) in the bottom left corner of your screen. Select "Settings" (the gear-shaped icon). Devices: In the Settings window, click on "Devices." Mouse Settings: In the Devices window, select "Mouse" from the left-hand menu. Adjust Pointer Speed: Under the "Mouse pointer speed" section, you will find a slider that allows you to adjust the speed. Move the slider to the left to decrease the mouse pointer speed, making it slower. Move the slider to the right to increase the mouse pointer speed, making it faster. Additional Mouse Options: For more advanced settings, click on "Additional mouse options" under the Related settings section. Pointer Options Tab: In the Mouse Properties window, go to the "Pointer Options" tab. You can further fine-tune your mouse speed by adjusting the "Select a pointer speed" slider. You can also choose to enhance pointer precision, which makes the mouse move more accurately across the screen. Apply and Save: After adjusting the mouse speed to your preference, click "Apply" and then "OK" to save your changes. Your mouse speed should now be adjusted according to your preferences. You can revisit these settings anytime to make further adjustments.
Message 19 of 19
bilal_fatah001
"After some investigation, I noticed this only seemed to be an issue for certain machines with certain graphics cards. Running some troubleshooting on this I found the issue only occurred when the graphics card was using DirectX 12, which was introduced in AutoCAD 2022.
The good news is this only affect a small number of graphics cards/drivers, and Autodesk is already aware and working towards a solution. Even better news is, there is a simply workaround for now.
To temporarily fix this, enter the new AutoCAD 2022 System Variable into the command line:
GFXDX12 and set it to 0
This will revert to DX11 on restart of AutoCAD."
This method solved my slow mouse in AutoCAD 2024
Full article : https://www.cadlinecommunity.co.uk/hc/en-us/articles/360018990917-AutoCAD-2022-Slow-Mouse
Forma Design Contest
