Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Advance Steel custom commands-share your ideas
814 REPLIES 814
Message 1 of 815
acbsdesign
93929 Views, 814 Replies
acbsdesign
It will be nice to learn more about custom commands / combination of Autocad and Advance Steel commands improving productivity.
To colleagues willing to share-Thank you.
Here is a tiny example:
"Hide parts with identical numbers"-used when parts are detailed using drawings styles.
^C^C_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
And another one:
"Hide Similar Advance Steel Objects":
^C^C_SelectSimilar \;_AstM4SwitchReprMode off
Ilko Dimitrov
ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
And another one:
Ilko Dimitrov
ACBS
814 REPLIES 814
Message 761 of 815
Julio_Soto
in reply to: handjonathan
Julio_Soto
so what happened today that this post all of a sudden does not meet your criteria to be pinned?
Message 762 of 815
bigcarl5000kg
in reply to: acbsdesign
bigcarl5000kg
probably the honesty of the feedback from the users was not in line with the eruptions on the sun, we can't imagine any other reason
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 763 of 815
bigcarl5000kg
Dear @handjonathan,
@handjonathan wrote:
Hi @Sebastian_Eiche
Thanks for reaching out on this issue. As community managers, we are tasked with keeping the forums structured. We have set criteria around the validity and amount of floated (pinned) topics we have on each forum board. Due to these reasons, I have unfloated this topic.
If you wish to chat with me to discuss this further, please drop me a DM, and we can have a quick call.
Why was this topic unpinned after publishing the information about Advance Steel going into maintenance mode? That seems to contradict what you stated above ... or have the rules suddenly changed (before and after)?
Dear @handjonathan,
Hi @Sebastian_Eiche
Message 764 of 815
handjonathan
Hi @bigcarl5000kg
As I have stated with @Sebastian_Eiche As community managers, we are tasked with keeping the forums structured. We have set criteria around the validity and amount of floated (pinned) topics we have on each forum board. Due to these reasons, I have unfloated this topic. The unfloating of this topic has nothing to do with the Autodesk update released yesterday regarding Advance Steel.
If you use this topic as a reference for custom commands, it would also be a good idea to bookmark it with your internet browser for easy reference, or maybe use this as a topic for a Community Voice Blog article.
I hope this explains it all, but if not, please feel free to contact me and we can arrange a call.
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Hi @bigcarl5000kg
Jonathan Hand
Message 765 of 815
handjonathan
handjonathan
Hi @acbsdesign
I have just checked the thread options and updated them to ensure the functionality is restored. A refresh of your browser should now show this functionality on the thread.
Jonathan Hand
Hi @acbsdesign
Jonathan Hand
Message 766 of 815
Sebastian_Eiche
I tried it in different browser and the 👍 Like button is not here.
my 2 cents:
And to the point of pinned threads: We have a "Whats New 2023" thread pinned..not needed anymore.
The amount ofpinned threads are understandable, but other forum parts have already 5-6...why should AS only have 4?
This thread here, has about 50000 views...it is good to have it in the beginning. Otherwise the users will post extra threads for each question and this will blow up this forum without need.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
my 2 cents:
Sebastian Eiche
Message 767 of 815
acbsdesign
acbsdesign
@handjonathan
Please leave this thread as it was by March 29th. *Threat has been moderated accordingly*
Expected something better from you.
@acbsdesign this topic has been moderated by @Tarek_K  according the community ground rules. Please review and stick to the ground rules. Thanks!
@handjonathan
Message 768 of 815
bigcarl5000kg
bigcarl5000kg
Every morning, when I open the w(W)indows and let the fresh air flow, which takes away the obsolete - unnecessary - with no chance of survival, I think how excited the users would be, if the developer knew and wanted to listen to them. It sounds like music from the future that someone fell asleep to.
Therefore, not only to Autodesk, try to open your w(W)indows and listen ... it can also cure software ailments. The call happens automatically ... and does not need a date 😀, thank you anyway @handjonathan
Message 769 of 815
handjonathan
Hi @Sebastian_Eiche
Can you check again? All are showing for me.
Jonathan Hand
Hi @Sebastian_Eiche
Jonathan Hand
Message 770 of 815
Sebastian_Eiche
yes now it's here
Sebastian Eiche
yes now it's here
Sebastian Eiche
Message 771 of 815
handjonathan
Thanks for confirming functionality is back @Sebastian_Eiche
Jonathan Hand
Jonathan Hand
Message 772 of 815
bigcarl5000kg
bigcarl5000kg
Dear AS community,
there are two excellent LISPs available from the ACAD Lisp forum to find multiple inserted blocks (nested blocks) at the same point (the difference between these LISPs is only in the visualization of the finding):
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-check-the-insertion-of-multi...
if it makes your work easier, then we will be more than satisfied 😉😀
Dear AS community,
Message 773 of 815
willianSWEAV
willianSWEAV
Hello.
Thanks for posting.
Sorry for my ignorance, but I would like to know how do I use custom commands?
I've seen all the custom command ideas shared by you guys (thanks again for doing so), but I don't know how to use them.
Thank you for your attention.
Hello.
Thanks for posting.
Message 774 of 815
Julio_Soto
in reply to: Jonathan3891
Julio_Soto
@Jonathan3891 wrote:
I thought it would be useful to be able to update multiple detail views, so I created this. Maybe some of you will find it useful.
(defun c:updateview ( / e i ss x )
  (setvar 'clayer "Standard")
  (if (setq ss (ssget))
    (progn
      (setq i 0)
      (repeat (sslength ss)
	(setq e (ssname ss i)
	      x (cdr (assoc 0 (entget e)))
	      i (1+ i)
	      );setq
	(command "_AstM4CommDetUpdateDetail" ss)
	);repeat
      );progn
    );if
  (princ)
Is there a reason you have to set the CLAYER to Standard?
    (progn
      (setq i 0)
	      i (1+ i)
	      );setq
	);repeat
      );progn
    );if
  (princ)
Message 775 of 815
Jonathan3891
in reply to: Julio_Soto
Jonathan3891
If I remember correctly on older version of AST if the layer was set to something different it would change the color or the layer of some items to the active layer when the detail was updated. I know that is no longer an issue so that could be taken out the lisp.
Jonathan Norton
Blog | Linkedin
Jonathan Norton
Blog | Linkedin
Message 776 of 815
vuongbui.nuce
same problem, can we have list?
Message 777 of 815
Sebastian_Eiche
nice video for the workflow:
https://www.youtube.com/watch?v=bc4P8NQISFQ
Sebastian Eiche
This video will show you how to create new categories on you tool palette and create new custom command, and also how to edit them later. This will hopefully help you to work faster and more efficiently ...
Sebastian Eiche
Message 778 of 815
acbsdesign
@Sebastian_Eiche
Thank you for sharing.
Completed training for another software.
Will live in two worlds now.
I guess.
@Sebastian_Eiche
I guess.
Message 779 of 815
fcorte
fcorte
Hi Ilko,
What is your opinion AS vs Tekla?
Pricewise comparison?
How "easy" to use and learn?
Hi Ilko,
Message 780 of 815
acbsdesign
acbsdesign
Hi @fcorte
I had to forget Advance for 1-2 weeks when I was learning Tekla, it was kind of hard because I had to work on ongoing projects and keep things running.
Pricewise it is worth the added cost I would say at 80% of their current cost, it is slightly higher than it is supposed to be.
It is double the price of AS.
It is not hard to learn, starting with a "Robot" talking - watching videos, and waiting for a place in guided training, that did not happen due to not enough folks for a group, and switched to E-learning, which was actually great. Quizzes all the time.
Modeling:
It takes time to get used to with the snaps and the filters, but in a few days everything starts to make sense.
Grid creation-top notch
Beams and columns-same
Components (connections)-well done except they do not always get modified from the first try.
Parametric modeling-awesome. Really, I am impressed.
The document manager-this is from another planet.
Cloning drawings-this is something that folks are asking, they have done it.
Drawings clean up-for heavy Autocad-based product users it is kind of weird, but hopefully will get used to it.
The bottom line, it should cost somewhere at 80% of what it is now.
One door closes, another opens.
All for good.
Hi @fcorte
Modeling:
All for good.
