It will be nice to learn more about custom commands / combination of Autocad and Advance Steel commands improving productivity.
To colleagues willing to share-Thank you.
Here is a tiny example:
"Hide parts with identical numbers"-used when parts are detailed using drawings styles.
^C^C_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
And another one:
"Hide Similar Advance Steel Objects":
^C^C_SelectSimilar \;_AstM4SwitchReprMode off
Ilko Dimitrov
ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
Solved by Jonathan3891. Go to Solution.
Solved by Sebastian_Eiche. Go to Solution.
Solved by acbsdesign. Go to Solution.
Solved by mick-CNF. Go to Solution.
Solved by vuk.vukanic. Go to Solution.
Solved by bigcarl5000kg. Go to Solution.
Solved by MetallPlanMerkinger. Go to Solution.
Solved by Matrix-Software. Go to Solution.
Solved by Ryan-J. Go to Solution.
Solved by Julio_Soto. Go to Solution.
@acbsdesign Wishing you the best in this new chapter!
It is sad that AD is forzing top-notch AS's users to look for the competition of AS. Your suggestions and input to improve AS is very valuable.
I hope to find a more affordable alternative than Tekla. I will wait for others users input.
Thank you for your wishes.
I will be still using AS on a daily basis, it is my preferred software for everything complex, drawings' quality is unmatched, for those caring about quality, it does make a difference.
Not closing the door 🙂.
Hi @acbsdesign,
I am glad that you successfully fought your way through the training for Tekla Structures. I have a similar experience, it's been a few years, it was like from another universe. Many months ago, not only based on market developments, we decided to develop our own real 3D CAD for our industry. As it uses direct input from our own static program, it is the most perfect solution for us. We will still be using Advance Steel in the background before we fully transition to our system. I wish everyone who is switching to another CAD a happy choice and much success. As the classic says, change is the only constant in the universe. Stay strong and healthy...
in fact, i very appreciate this post and all guy make solution. But i dont understand why value post does not pin in board? too difficult to find this post. i find many solution for problem in this post
it was pinned, but the forum administrator canceled it
It was pinned, but it was said by the moderator it is not structured or something similar.
Whatever, it helped us over the past few years to improve the workflow, this is most important.
I would like to thank everyone again for all ideas and suggestions.
This is what made this place great-bringing users together.
It is sad to see the development of Advance Steel abandoned in 2023 just because Revit is all they want.
(my opinion only)
hi @acbsdesign in my opinion too, Revit it is not the solution or the tool we need ..
Hi folks,
Is it possible to get the image files from the ribbon-any success?
Thank you.
@bigcarl5000kg -Thank you for the image files from the tool palette, they are great.
Which one do you need?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
the pics are stored in the dll in the toolbarsfolder:
these could be extract with some tools. I used Resource Hacker in the past which worked good
Sebastian Eiche
@Julio_Soto wrote:you were able to get the image files from the tool palettes?
I think they were posted in this thread.
Will look further, but it was last year.
Thank you.
Not sure what everyone is up to now, such an uncertainty with Autodesk and Advance. I no longer want to be there.
Learned Tekla, most of it, some of it, enough of it, enough to be competitive, they say, no one can learn everything.
And it may be true because I am not a programmer.
And we don't have to be.
What will the programmers do otherwise?
Recorded macros, many of them.
Tekla doesn't have some of out of box commands we have in Advance-select objects connected in the field, for example, ...why do I need this. And why do I need that?
"Because I never needed it"
See? There are some subjects everywhere. :)))
Thank you for the help.
Priceless.
I have another lisp routine I've created out of necessity.
Have you ever started cutting drawings and realize some objects are showing that shouldn't because you didn't set the model role? Does it take you a minute to scroll through the list to find the right one?
If you've ever experienced any part of this scenario then this lisp might be useful to you!
It's easy to use! Activate the command "SETROLE" then enter the model role then select all the objects that apply. If you're not sure what the internal role name is (the one stored in MT) then enter "?" and it will open the attached excel spreadsheet that list all the roles.
Make sure to put the spreadsheet in a support folder you have pathed.
Thank you for sharing.
Have a great evening.
hello Sebastian, can you make quick video for this command? i try it but fails
Hello@Jonathan3891
I have seen your Lisp for setting the model role.
I'm looking for a command to set the checkboxes from the user Attributes.
Do you have an Idea, if that checkboxes can be changed with lisp?
first you need the names of the checkboxes (similar to the DCL menu) ... we have been searching for a long time and in vain
