Advance Steel custom commands-share your ideas
acbsdesign
Mentor Mentor
Message 1 of 815
acbsdesign
It will be nice to learn more about custom commands / combination of Autocad and Advance Steel commands improving productivity.
To colleagues willing to share-Thank you.
Here is a tiny example:
"Hide parts with identical numbers"-used when parts are detailed using drawings styles.
^C^C_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
And another one:
"Hide Similar Advance Steel Objects":
^C^C_SelectSimilar \;_AstM4SwitchReprMode off
Ilko Dimitrov
ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Accepted solutions (126)
Replies (814)
Message 781 of 815
fcorte
@acbsdesign  Wishing you the best in this new chapter!
It is sad that AD is forzing top-notch AS's users to look for the competition of AS. Your suggestions and input to improve AS is very valuable.
I hope to find a more affordable alternative than Tekla. I will wait for others users input.
https://youtu.be/lShF4FKf4nU
Message 782 of 815
acbsdesign
@fcorte
Thank you for your wishes.
I will be still using AS on a daily basis, it is my preferred software for everything complex, drawings' quality is unmatched, for those caring about quality, it does make a difference.
Not closing the door 🙂.
Message 783 of 815
bigcarl5000kg
Hi @acbsdesign,
I am glad that you successfully fought your way through the training for Tekla Structures. I have a similar experience, it's been a few years, it was like from another universe. Many months ago, not only based on market developments, we decided to develop our own real 3D CAD for our industry. As it uses direct input from our own static program, it is the most perfect solution for us. We will still be using Advance Steel in the background before we fully transition to our system. I wish everyone who is switching to another CAD a happy choice and much success. As the classic says, change is the only constant in the universe. Stay strong and healthy...
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 784 of 815
vuongbui.nuce
in fact, i very appreciate this post and all guy make solution. But i dont understand why value post does not pin in board? too difficult to find this post. i find many solution for problem in this post
Message 785 of 815
bigcarl5000kg
it was pinned, but the forum administrator canceled it
Message 786 of 815
acbsdesign
@vuongbui.nuce
It was pinned, but it was said by the moderator it is not structured or something similar.
Whatever, it helped us over the past few years to improve the workflow, this is most important.
I would like to thank everyone again for all ideas and suggestions.
This is what made this place great-bringing users together.
It is sad to see the development of Advance Steel abandoned in 2023 just because Revit is all they want.
(my opinion only)
Message 787 of 815
bigcarl5000kg
hi @acbsdesign  in my opinion too, Revit it is not the solution or the tool we need ..
Message 788 of 815
acbsdesign
Hi folks,
Is it possible to get the image files from the ribbon-any success?
Thank you.
@bigcarl5000kg -Thank you for the image files from the tool palette, they are great.
Message 789 of 815
Sebastian_Eiche
Which one do you need?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 790 of 815
Julio_Soto
you were able to get the image files from the tool palettes?
Message 791 of 815
Sebastian_Eiche
the pics are stored in the dll in the toolbarsfolder:
these could be extract with some tools. I used Resource Hacker in the past which worked good
Sebastian Eiche
Message 792 of 815
acbsdesign
I think they were posted in this thread.
Will look further, but it was last year.
Message 793 of 815
acbsdesign
@Sebastian_Eiche
Thank you.
Not sure what everyone is up to now, such an uncertainty with Autodesk and Advance. I no longer want to be there.
Learned Tekla, most of it, some of it, enough of it, enough to be competitive, they say, no one can learn everything.
And it may be true because I am not a programmer.
And we don't have to be.
What will the programmers do otherwise?
Recorded macros, many of them.
Tekla doesn't have some of out of box commands we have in Advance-select objects connected in the field, for example, ...why do I need this. And why do I need that?
"Because I never needed it"
See? There are some subjects everywhere. :)))
Thank you for the help.
Priceless.
Message 794 of 815
Jonathan3891
I have another lisp routine I've created out of necessity.
Have you ever started cutting drawings and realize some objects are showing that shouldn't because you didn't set the model role? Does it take you a minute to scroll through the list to find the right one?
If you've ever experienced any part of this scenario then this lisp might be useful to you!
It's easy to use! Activate the command "SETROLE" then enter the model role then select all the objects that apply. If you're not sure what the internal role name is (the one stored in MT) then enter "?" and it will open the attached excel spreadsheet that list all the roles.
Make sure to put the spreadsheet in a support folder you have pathed.
Jonathan Norton
Blog | Linkedin
Message 795 of 815
acbsdesign
@Jonathan3891
Thank you for sharing.
Have a great evening.
Message 796 of 815
vuongbui.nuce
hello Sebastian, can you make quick video for this command? i try it but fails
Message 797 of 815
MetallPlanMerkinger
Hello@Jonathan3891
I have seen your Lisp for setting the model role.
I'm looking for a command to set the checkboxes from the user Attributes.
Do you have an Idea, if that checkboxes can be changed with lisp?
Message 798 of 815
bigcarl5000kg
Hi @MetallPlanMerkinger,
first you need the names of the checkboxes (similar to the DCL menu) ... we have been searching for a long time and in vain
Message 799 of 815
FCort
Will all these lisps and custom commands work in Revit_ Advance Steel ?
Message 800 of 815
Jonathan3891
LISP is not compatible with Revit.
.NET or C# is the language used.
Jonathan Norton
Blog | Linkedin
