Advance Steel custom commands-share your ideas
acbsdesign
Mentor Mentor
Message 1 of 815
acbsdesign
It will be nice to learn more about custom commands / combination of Autocad and Advance Steel commands improving productivity.
To colleagues willing to share-Thank you.
Here is a tiny example:
"Hide parts with identical numbers"-used when parts are detailed using drawings styles.
^C^C_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
And another one:
"Hide Similar Advance Steel Objects":
^C^C_SelectSimilar \;_AstM4SwitchReprMode off
Ilko Dimitrov
ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Accepted solutions (126)
Replies (814)
Message 101 of 815
Drawtech
More drawing labels:
If you have a standard note on your GA drawings covering steel grade, but need to note only any members that are a different grade within their label, use this label definition (or a variation of it) for everything:
Note: change the red marked grade to your standard grade:
%MainPartPosNum - %Name %%script(Mat = "%Material": MatStd = "S275": Compare = StrComp(Mat, MatStd, 1): If Compare <> 0 then appendstring Mat)
This will then only include the grade in the label if non-standard.
Dave Gronow
Drawtech Services Ltd
Message 102 of 815
Drawtech
The default slot length in a label is the overall length.
If you want the slot length between hole centres in the label:
%BoltCount No. %Diameterøx%%script(LenTotal = %Length: LenCtrs = LenTotal-%Diameter: appendstring LenCtrs)ctrs slotted holes
Dave Gronow
Message 103 of 815
acbsdesign
@Anonymous wrote:
@Adrian.Mangan wrote:
This is a great one Ilko, I have tried to adjust it myself it add a remove markings before the command but I cannot find it in the CUI to add it. Any ideas? This would be a great one for me. Thank you for all your input.
Adapted from Sebastian's "Select Main Part"
Isolate Assembly (with a remove all marking command at the start, without that it will isolate the assembly of the selected part, plus any currently marked parts). Also an Escape at the end i pinched from one of Ilko's.
_^C^C_AstM4CommUnmarkObjects;_AstM4SwitchReprMode MAINSTRUCTURE \;AstM4CommSelectMarkedObjects ; _AstM10ViewSelObjects;;_AstM4CommUnmarkObjects;;;graphscr;redraw;
Adapted from Ilko's "Isolate Identical Parts" (with a remove all marking command at the start, without that it will isolate the identical parts, plus any currently marked parts). Also an Escape at the end i pinched from one of Ilko's.
_^C^C_AstM4CommUnmarkObjects;_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ; _AstM10ViewSelObjects;;_AstM4CommUnmarkObjects;;;graphscr;redraw;
If, like the commands above, a command clears all marking I put a warning in the command name. That's a lesson I learned the hard way!
For isolate identical parts-I couldn't get the parts unmarked, after I execute the command, and show all, they are still marked.
Message 104 of 815
Ilko,
You have to start the command, then select your part. If you select the part, then start the command it misbehaves.
I think it's because of the clear marking command at the beginning. That is not a command that requires an object to be selected.
For this reason the modified commands won't work as part of your context sensitive right click menu.
There must be a way though... consider "Clear marking + display objects connected in shop" on the Advance Tool Palette.
That command should form the first half of our Isolate Assembly command, but I can't see the difference. I'll work on it.
Message 105 of 815
acbsdesign
@Anonymous
I made it work:
Just I add this to all commands that need Unmarking:
_AstM4CommUnmarkObjects;graphscr;redraw;
Message 106 of 815
@acbsdesign wrote:
@Anonymous
I made it work:
I can only get the opposite effect, it will work now if I select the object first. But not if I want to start the command, then select an object. This is driving me mad!
Does it work both ways for you?
Message 107 of 815
acbsdesign
@Anonymous wrote:
@acbsdesign wrote:
@Anonymous
I made it work:
No,
I start the command first, for both Isolate Identical Parts and Hide Identical Parts, I have them in the Default Shortcut menu.
Message 108 of 815
vuk.vukanic
Thank you for all the contributions, here is a couple of tips I didn't see in previous posts:
1. I look at every opportunity to eliminate unnecessary mouse movement (hence i use keyboard shortcuts as much as possible). You can use the Action Recorder to save a particular set of commands (steps) and assign a keyboard shortcut alike shown in the video. I have attached a file containing those I use, they are the most basic (and most used in my case) like: placing and rotating UCS, orient view at curent ucs and zoom at 500 magnification, change from wireframe to conceptual, isolate assembly, clear marked objects, and so on. Just copy folder to
C:\Users\UserName\AppData\Roaming\Autodesk\Advance Steel 2019\R23.0\enu\Support and the commands will be available. To see what they do, you need to turn on the manage tab via CUI.
1 or 2 keys + space = hours saved
https://autode.sk/2P62lXS
2. Have you ever had the need to change project information (general notes and alike included) after finishing drawings? Updating Page Header can work, but... Here is a non conventional workflow I use. It is based on XREF. I created .dwgs that contain mock up information (or just a border to indicate intended space for it) and loaded all of the above into prototypes. My XREFs have generic names that never change, so they can be switched with one another. It took me literally 5min to change general notes on approximately 500 drawings and run printing (the print to pdf took about 4hours). I'm still experimenting with this, but found no downsides so far. If you are curious, it's explained in the video accessible here:
https://autode.sk/2yxm11j
Hopefully someone will find it useful, or a way to make it better and share 😄
thx
Easy things are not worth the effort
http://www.teamcad.rs
Message 109 of 815
acbsdesign
@vuk.vukanic
These two a great, changing notes on all dwgs is a pain in the neck, I will implement them and use them.
Thank you very much for sharing.
Message 110 of 815
Adrian.Mangan
Interesting, will have to record these and learn how to apply them.
Thank you
Message 111 of 815
pinnacledrafting
Since we are talking about customizing and hopefully I didn't miss this earlier in the discussion, does anybody know what makes the Bolt/Hole/Anchor/Stud icon in the Switch panel change? The "toggle switch display SP/MP" in the Part Marks panel does the same thing. I created a custom tab for modeling to streamline the process, to exclude many icon/commands I never use and all the "switch/toggle" lost the ability to switch. I compared side by side in the CUI the original icon and the one I copied into my custom panel and the only difference I see is in the "element ID" under the "Advanced" dialog in the buttom properties.
BTW, some really good customizing ideas on here, keep'em coming.
I've got some drawing LISPs I've made that I can share later.
Bill
Message 112 of 815
Masibanda-CE
These are excellent Dave! I'm starting to see that AS is much closer to Tekla in its ability to manipulate data now!
A question for you: Is there a resource for finding the available "variables" you can call up? One of my biggest gripes was not being able to put the model role in the title. With this scripting I can see a possibility. I've tried a few  ... ModelRole, Role, Rolle, etc but can't get it.
Cheers,
Gary
Message 113 of 815
Sebastian_Eiche
There's a table for it, if you open the table editor and search for token, you will find it I thought it's located in the kernel database.
But I think not all token could be used. This have for example the following reason: if you don't set the box in the property to true to create a difference between two objects by using the role. The result in the numbering could be, that two beams with the same role could have the same number. And if you want to add the role of the beam...which should AS use?
Therefore some token could not be used
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 114 of 815
@acbsdesign wrote:
@Anonymous wrote:
@acbsdesign wrote:
@Anonymous
I made it work:
No,
Please find below variations on some of the recent custom commands.
These are all commands where it matters whether you select the object and then initiate the command, or whether you initiate the command and then select the object.
Personally I prefer to select the object first, but that's just my natural instinct, YMMV.
If someone could find the command string that would make them work both ways that would be the most elegant solution, I don't know enough about command strings to be able to do that.
Isolate Assembly (Clears Marking) (command first)
_^C^C_AstM4CommUnmarkObjects;_AstM4SwitchReprMode MAINSTRUCTURE \;_AstM4CommSelectMarkedObjects ; _AstM10ViewSelObjects;;_AstM4CommUnmarkObjects;;;graphscr;redraw;
Isolate Assembly (Clears Marking) (select object first)
_^C^C_AstM4CommUnmarkObjects;_AstM4SwitchReprMode MAINSTRUCTURE graphscr;redraw;_AstM4CommSelectMarkedObjects ; _AstM10ViewSelObjects;;_AstM4CommUnmarkObjects;;;graphscr;redraw;
Isolate Identical Parts (Clears Marking) (command first)
Isolate Identical Parts (Clears Marking) (select object first)
_^C^C_AstM4CommUnmarkObjects;_AstM5equalpartsMarkSame graphscr;redraw;_AstM4CommSelectMarkedObjects ; _AstM10ViewSelObjects;;_AstM4CommUnmarkObjects;;;graphscr;redraw;
Hide Identical Parts (Clears Marking) (command first)
^C^C_AstM4CommUnmarkObjects;_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
Hide Identical Parts (Clears Marking) (select object first)
^C^C_AstM4CommUnmarkObjects;_AstM5equalpartsMarkSame graphscr;redraw;_AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
Hide Similar Parts (command first)
Hide Similar Parts (select object first)
^C^C_SelectSimilar graphscr;redraw;_AstM4SwitchReprMode off
Message 115 of 815
acbsdesign
@Anonymous
Thank you for the two options and commands being summarized
@Drawtech
Thank you for sharing all these options
Is there any way to insert a block in the label per the attached screenshot below (the slot direction symbol):
Block in LabelBlock in Label
And is it possible to insert a block in Detail Title:
Block in Detail TitleBlock in Detail Title
Thank you for your time.
Message 116 of 815
Some quick Icons for the following commands
Hide parts with identical numbers (Clears marking)
Trim / Extend to system
Trim / Extend to line
Bolts off
Bolts Solid
modelboxes and jointboxes off
connection elements off
Message 117 of 815
acbsdesign
A small one,
Not a custom command, but at time saver-match properties of a pre-defined dimension chain and style:
https://autode.sk/2ust5Kc
Message 118 of 815
Adrian.Mangan
Interesting
Message 119 of 815
acbsdesign
Interesting
I am going to prepare a small table with pre-defined dwg styles, and properties (text below, text above etc) and I will place it in all prototypes, for now, this is the fastest way to change the dim's until we would be able to do it within the dwg style, I doubt if it will ever happen.
Message 120 of 815
Adrian.Mangan
Old table with commands for AS, taken from 2015 Management tools. May be off use to some novices like myself.
Attached.
P.S. no idea if these work
