Announcements
Advance Steel custom commands-share your ideas
acbsdesign
acbsdesign
It will be nice to learn more about custom commands / combination of Autocad and Advance Steel commands improving productivity.
To colleagues willing to share-Thank you.
Here is a tiny example:
"Hide parts with identical numbers"-used when parts are detailed using drawings styles.
^C^C_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ;_AstM4SwitchReprMode off
And another one:
"Hide Similar Advance Steel Objects":
^C^C_SelectSimilar \;_AstM4SwitchReprMode off
Ilko Dimitrov
ACBS
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Accepted solutions (126)
Replies (814)
Adrian.Mangan
This is a good one Ilko, thank you, just setting up my custom commands now. I like some of your others too.
Adrian.Mangan
These ones are great too, love the extend to column
Adrian.Mangan
These are particularly useful when I go back to trim system line sometimes after changing the design, originally I would split the beam but this was no use as the numbering is then lost, then I was manually dragging beam back, now with this it save me a lot of time. Thank you.
Adrian.Mangan
Please excuse my ignorance Sebastian, does that mean if I add the weld in the model it will automatically come in without the weld thickness value but if I add it manually in the detail it will have that value?
Sebastian_Eiche
This thickness should be not shown in both cases. Egual if it's placed in the model or detail.
I set a thickness which is never used in reality, to have these option. In Germany (I don't know if other countries use this too) this option was used to have a clean detail. And then in pageheader the most have the statement:
All not defined welds had to be done in 4mm (for example).
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Adrian.Mangan
Great Tip Alecks
Adrian.Mangan
Feel a little guilty I'm just taking and not giving, haha
I felt like that, but I don't have any custom commands to contribute Smiley Sad
I did knock up a couple of icons for the commands to ease my guilt though, see if that helps Smiley Wink
Adrian.Mangan
This is a great one Ilko, I have tried to adjust it myself it add a remove markings before the command but I cannot find it in the CUI to add it. Any ideas? This would be a great one for me. Thank you for all your input.
acbsdesign
Trim extend to system line
https://youtu.be/ptw__t4sDCw
Adrian.Mangan
game changer
acbsdesign
@Anonymous @Adrian.Mangan
I am sure you will contribute down the road.
I wish more AS users are taking part of this. @bukko for example, or @Drawtech, or @iwafb -I know everyone is busy, but a few minutes spent here would save hundreds of hours.
It can be a trick, use of dynamic blocks for example, not necessary to be a custom command.
Anything that will help with speed and accuracy.
And appearance-both for interface and for drawings.
Masibanda-CE
Here are ones that I've added to shortcut menus that save me heaps of effort ... 1 second at a time:
Deafult MenuDeafult MenuEdit MenuEdit MenuObject Snap & Grip Points MenusObject Snap & Grip Points Menus
Adapted from Sebastian's "Select Main Part"
Isolate Assembly (with a remove all marking command at the start, without that it will isolate the assembly of the selected part, plus any currently marked parts). Also an Escape at the end i pinched from one of Ilko's.
_^C^C_AstM4CommUnmarkObjects;_AstM4SwitchReprMode MAINSTRUCTURE \;AstM4CommSelectMarkedObjects ; _AstM10ViewSelObjects;;_AstM4CommUnmarkObjects;;;graphscr;redraw;
Adapted from Ilko's "Isolate Identical Parts" (with a remove all marking command at the start, without that it will isolate the identical parts, plus any currently marked parts). Also an Escape at the end i pinched from one of Ilko's.
_^C^C_AstM4CommUnmarkObjects;_AstM5equalpartsMarkSame \;AstM4CommSelectMarkedObjects ; _AstM10ViewSelObjects;;_AstM4CommUnmarkObjects;;;graphscr;redraw;
If, like the commands above, a command clears all marking I put a warning in the command name. That's a lesson I learned the hard way!
Drawtech
@acbsdesign
Ilko,  OK - how about custom drawing labels using vb script...
The tokens %ObjectTopLevel and %ObjectBottomLevel add a "-" if negative but not "+" when positive.
Also, they omit trailing zeros.
...so how about these label definitions:
(just paste into a drawing label dialog)
T.O.S. %%script(Q = (%ObjectTopLevel): If Q>0 then appendstring ("+" & (FormatNumber(Q,3))) else appendstring (FormatNumber(Q,3)))
B.O.S. %%script(Q = (%ObjectBottomLevel): If Q>0 then appendstring ("+" & (FormatNumber(Q,3))) else appendstring (FormatNumber(Q,3)))
Dave Gronow
Drawtech Services Ltd
Drawtech
More drawing labels:
For foundation and base plate levels on plan drawings:
We generally use 25mm pack & grout in the UK.  Change the red number to suit what you use:
U/S Base Plate %%script(Q1 = (%ObjectBottomLevel): If Q1>0 then appendstring ("+" & (FormatNumber(Q1,3))) else appendstring (FormatNumber(Q1,3)))#NewlineT.O.C. Found'n %%script(Q1 = (%ObjectBottomLevel-0.025😞 If Q1>0 then appendstring ("+" & (FormatNumber(Q1,3))) else appendstring (FormatNumber(Q1,3)))
Dave Gronow
acbsdesign
This is what I was talking about, do not hide opinion due to fear account will be suspended, or knowledge, and experience under the pillow-add something.
I am already using 3 of your icons.
I will test these two commands as modified. I was looking to get the parts unmarked-thank you.
Good thinking, keep posting.
acbsdesign
@Drawtech
Wait wait, slow down, I am completely new to this.
Looking fwd to use it.
Thank you, David.
Drawtech
Some for csk and slotted holes:
%BoltCount - %Diameterø CSK for M%%script(D = %Diameter: if D < 12 then appendstring D-1 else appendstring D-2) %%script(if %BoltCount = 1 then appendstring "Bolt" else appendstring "Bolts")
%BoltCount - %Diameterø x %Length %%script(if %BoltCount = 1 then appendstring "Slot" else appendstring "Slots")
Dave Gronow
Drawtech
'Assembly detail call off - if coating None, leave off:
%Quantity No. Mkd %MainPartPosNum #Height(3.50)%%script(Coat = "%Coating": NoCoat = "None": Compare = StrComp(Coat, NoCoat, 1): If Compare <> 0 then appendstring "("&Coat&")")
Dave Gronow
