Hi just installed AutoDesk MoldFlow 2010-R2 on a Windows 7 64bit machine and when going to launch it I received the attached screen shot.
I've got the correct license server, it's pingable, and the other users who are all on Windows XP 32bit are having no issues.
I get the same error after installing Moldflow 2011.
I've checked the license server manager, and it's pointing to the correct license.
Any help would be awesome!
Thanks!
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Moldflow licensing is a little different than other products, to my memory. I have solved this problem for a customer in the past but failed to take down any notes on what I did. I do know there is additional license configuration that needs to take place to make it work though.
i have the same problem as darken98.
"Autodesk security failure"
is there any solution to fix that problem?
