Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Script Error - 'toUpperCase' of undefined or null reference
4 REPLIES 4
CoscoFire
484 Views, 4 Replies
Just downloaded the Revit 2015 trial, installed it, and now, after logging in with Autodesk User ID, this is the result:
What the hell do I do????
4 REPLIES 4
TravisNave
in reply to: CoscoFire
This is likely a problem with your Internet Explorer.  What version are you running and is it your default browser?
Other people are reporting the same issue also, so it is possible that the problem could be on the website.
Edit:  I am going to try to escalate this.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
CoscoFire
in reply to: TravisNave
Thank you very much.  Yes I need a resolution to this ASAP.
CoscoFire
Any updates on this fix?
You were correct in your initial assessment.  I have Chrome as my browser.  I changed the default to IE, and it worked just fine.
Thanks!!
TravisNave
I have received notification and confirmation from other users that this is now fixed.  I have been trying to hit all the threads about this.  Try it now and let us know.  Thanks!
Autodesk Forums:
