Revit MEP Forum
Amtech addin for Revit
2 REPLIES 2
1735 Views, 2 Replies
We have building design suite premium 2014 installed on our machines, however when I try to link Amtech Pro Design to the Revit software i get an error saying Amecth can not find Revit installed on this machine. Has anyone else had this problem? Amtech has stated it is a Autodesk problem and not their software.
2 REPLIES 2
TravisNave
It could be that the plugin is looking for a different version of Revit that gets installed with the design suite.  I know that there are multiple feature codes for Revit that cause licensing headaches with the suite flavors.  I suspect you might be experiencing the same fate.  You might ask the company how it validates the version so you can make sure.  Just a thought.
Autodesk Forums:
We have the same problem. It would seem it is only compatiable with MEP which would appear to differ from design suite!! 😞 Anyone managed to get it to work??
