Hi All,
Hope someone can explain to me following error:
Requests from the same USER/HOST do not consume a new license
We had an other license server running before but that one crashed today:-(.
I register the license again and us it on a other license server we already had running for Autodesk Vault
Below the error:
Diagnostics
FLEXnet diagnostics on Fri 7/13/2012 11:57
License file: C:\Program Files\Autodesk Network License Manager\Vault2012\VLTWG_Invento_2012.lic
"85752VLTWG_2012_0F" v1.000, vendor: adskflex
License server: DE-S-NL0147
floating license starts: 1-jan-1990, no expiration date
This license can be checked out
"85796PDSU_2012_0F" v1.000, vendor: adskflex
The user can't use inventor now:-(.
Solved by TravisNave. Go to Solution.
post the status inquiry
what error messge is the user getting when the user launches inventor?
DarrenP
Hi melzenaar,
You might also search for an answer or post this question to the Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
I hope this helps.
Curtis
Hi All,
I think I have to be more patient next time, Inventor works now 🙂
Perhaps there is some time between before the license becomes active.
I'm still wondering what this message means:
Thanks for all your help
Michel
It means that if the same user or computer launches an additional copy of the software, it will not take another license. Thus if you have two copies of Inventor 2013 launched, you still only use one seat.
