Hi, I was trying to uninstall revit 2013 (the combo version?) after updating to Update 2 but apparently something corrupted the installer data and now I can't uninstall it through the system's Control Panel. Is there like a way to run the installer in maintenance mode manually like through the command prompt?
I'm trying to use that new Windows Fix It thing but it seems ineffective as it's just running there with no feedback and I can't tell if it's actually working.
(And in other word: can the installer be improved so if you run from the disc and such it can act as an uninstaller also?)
Windows XP SP3
