When trying install Sketchbook Pro 2011 on Windows 7 I get the following error when trying to decompress the installation files using the install wizard.
Are you installing with local admin rights? has UAC been disabled? Is your anti-virus been temporarily disabled? Are you changing the default install path? Does your Windows account use roaming profiles?
Tried with local admin rights, the workstation is in a domain. UAC is not turned off. AV has been removed at time of install. We do not use roaming profiles.
Matt
