Installation & Licensing
Revit Architecture 2014 Failed Install 1619
21 REPLIES 21
Message 1 of 22
hrm3
4679 Views, 21 Replies
I have tried this Revit Arch 2014 deployment on several machines with similar results.  (all have Revit 2012 installed which much remain)  below is the error log.  Please assist.  Thank you.
2013/6/6:15:47:27 HRM NCR-LAPTOP === Setup started on NCR-LAPTOP by HRM ===
2013/6/6:15:47:27 HRM NCR-LAPTOP Path_Length: 149
2013/6/6:15:47:27 HRM NCR-LAPTOP Current Directory \\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img
2013/6/6:15:47:27 HRM NCR-LAPTOP Launch
2013/6/6:15:47:27 HRM NCR-LAPTOP CommandLine /qb /I \\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\Revit2014.ini /language en-us
2013/6/6:15:47:27 HRM NCR-LAPTOP Current Directory C:\Users\hrm\AppData\Local\Temp\_AI2EDC.tmp
2013/6/6:15:47:40 HRM NCR-LAPTOP === Setup ended ===
2013/6/6:15:47:34 HRM NCR-LAPTOP === Setup started on NCR-LAPTOP by HRM ===
2013/6/6:15:47:34 HRM NCR-LAPTOP Path_Length: 149
2013/6/6:15:47:34 HRM NCR-LAPTOP Current Directory C:\Users\hrm\AppData\Local\Temp\_AI2EDC.tmp
2013/6/6:15:47:34 HRM NCR-LAPTOP Launch
2013/6/6:15:47:34 HRM NCR-LAPTOP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\hrm\AppData\Local\Temp\_AI2EDC.tmp\Setup\RevitSetup.dll
2013/6/6:15:47:34 HRM NCR-LAPTOP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/6/6:15:47:40 HRM NCR-LAPTOP Installing Microsoft Visual C++ 2005 Redistributable (x86): "\\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\hrm\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/6/6:15:47:51 HRM NCR-LAPTOP Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/6/6:15:47:51 HRM NCR-LAPTOP Installing DirectX® Runtime: "\\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\3rdParty\DirectX\DXSETUP.exe" /silent
2013/6/6:15:48:08 HRM NCR-LAPTOP Install DirectX® Runtime Succeeded
2013/6/6:15:48:08 HRM NCR-LAPTOP Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit Architecture 2014" SETUP_PACKAGECODE={7346B4A0-1400-0100-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/6/6:15:48:29 HRM NCR-LAPTOP Install FaroSDK Succeeded
2013/6/6:15:48:29 HRM NCR-LAPTOP Installing Autodesk® Revit® Architecture 2014: TRANSFORMS="\\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\x64\en-us\RAC2014\RAC2014.mst;\\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\x64\RAC2014\RAC2014-Revit2014.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit Architecture 2014" SETUP_PACKAGECODE={7346B4A0-1400-0100-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=",Internet Explorer 7,SSE2 Support Check,Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2005 Redistributable (x86),Microsoft Visual C++ 2005 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),{04B34E21-5BEE-3D2B-8D3D-E3E80D253F64},{B42E259C-E4D4-37F1-A1B2-EB9C4FC5A04D},{14866AAD-1F23-39AC-A62B-7091ED1ADE64},{4B90093A-5D9C-3956-8ABB-95848BE6EFAD},{C3A57BB3-9AA6-3F6F-9395-6C062BDD5FC4},{6DA2B636-698A-3294-BF4A-B5E11B238CDD},{F6F09DD8-F39B-3A16-ADB9-C9E6B56903F9},{8CCEA24C-51AE-3B71-9092-7D0C44DDA2DF},Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86),Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64),.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language pack,DirectX® Runtime,{8A470330-70B2-49AD-86AF-79885EF9898A},;{11672AB2-3D48-4D38-9123-719E5FF93333},{644F9B19-A462-499C-BF4D-300ABC2A28B1},{51BF3210-B825-4092-8E0D-66D689916E02},{5C29CC1F-218F-4C30-948A-11066CAC59FB},;;" ADSK_SOURCE_ROOT="\\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/6/6:15:48:33 HRM NCR-LAPTOP Install Autodesk® Revit® Architecture 2014 Failed Installation aborted, Result=1603
2013/6/6:15:48:36 HRM NCR-LAPTOP Rollback FaroSDK Succeeded
2013/6/6:15:48:37 HRM NCR-LAPTOP Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/6/6:15:48:37 HRM NCR-LAPTOP Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2013/6/6:15:48:40 HRM NCR-LAPTOP === Setup ended ===
21 REPLIES 21
Message 2 of 22
TravisNave
in reply to: hrm3
See if you can find the Revit install log.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 22
hrm3
in reply to: TravisNave
I'm confused, wasn't that what I posted?
Message 4 of 22
in reply to: hrm3
I am having the EXACT problem excpet it's on BDSP2014 (A Revit only install). My log looks identical and the internet isn't helping me very much.
Message 5 of 22
TravisNave
in reply to: hrm3
You should have a 2nd install log in the %TEMP% folder of the client.
Autodesk Forums:
Message 6 of 22
hrm3
Attached is the install log from another machine with the exact same log errors.  It looks as though the RAC2014.mst is getting hung up with authorization.  The deployment is being run as administrator.  The only way I've found to get the deployment to work is to disable UAC which I have no desire to do for 50 computers that need this installed.  Especially since disabling UAC requires a reboot.
I can't be the only one that has run across this problem.....?
Message 7 of 22
in reply to: hrm3
Mine looks slightly different as I get a 1603 before I get 1619. Very frustrating.
Message 8 of 22
hrm3
in reply to: hrm3
@cstarr - mine is giving 6013 error on the revit architecture install then 6019 on the other files. Try and turn your UAC to never notify, reboot then try the deployment. Likely you'll find it works. Although this is not an acceptable solution for deployments.
Message 9 of 22
in reply to: hrm3
No, still failing. And failing on every computer I try to put it on. This is frustrating. Any help Adesk?
InstallAutodesk® Revit® 2014FailedInstallation aborted, Result=1603
This is BDSP14.
Message 10 of 22
hrm3
in reply to: hrm3
Agree. Mine is still failing also. I've had hit or miss success with disabling UAC....
Need assistance from autodesk.
Message 11 of 22
DannyHubbard
cstarr,
You install is failing because you are using Shared Content with Revit, but are trying to use a mapped drive letter instead of a UNC path.
Error from your log file:
MSI (s) (AC:30) [16:32:59:099]: Product: Revit 2014 - - Error 1327.Invalid Drive: V:\
In Windows 7 or 8 with UAC on if a drive is mapped from a command prompt, like via a log in script, the drive won't be availabe in Windows Explorer so the install of Revit doesn't know the drive exists.
Check out my last post for this previous discussion.
http://forums.autodesk.com/t5/Installation-Licensing/BDS-Premium-Deployment-install-fails-with-x64/t...
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 12 of 22
DannyHubbard
in reply to: hrm3
bobmock4292,
This install log shows Revit installed successfully.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 13 of 22
hrm3
in reply to: DannyHubbard
Danny,
Thanks for responding.  My appoligies, that was the install log from a machine I manually installed Revit.  Attached is the log file from a machine i just tried to deploy 2 a few minutes ago and it failed.  if you could assist that would be great.  Thank you.
Message 14 of 22
hrm3
in reply to: hrm3
It looks like I might have the same mapped drive issue for shared content.  Will try and edit the deployment to use UNC paths and try again.
Message 15 of 22
Danny, thank you for the response and help.
We turn UAC off on every machine here and it is currently off on mine as well. I am using Shared Content, but the only place I am referencing our "V" drive is in the Revit directory locations. I am also unchecking all content as part of the deployment since I don't want every install to attempt to install the content to the shared location (it already exists there), unless I am misunderstanding the process.
I can try to use UNC pathing to see if that fixes the problem, but would rather not. We have always use drive mappings in the past with no problems.
-Clay
Message 16 of 22
TravisNave
I agree that drive mappings are severely problematic and UNC pathing should always be used.
Autodesk Forums:
Message 17 of 22
DannyHubbard
in reply to: hrm3
bobmock4292,
You problem may be a corrupt deployment, looks like the install is having probelms accessing some files from your deployment.
From the log file:
MSI (s) (2C:4C) [10:44:40:822]: Product: Revit Architecture 2014 - - Error 1309.Error reading from file: \\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\x64\RAC2014\Program Files\Autodesk\Root\Textures\Reflect.exr.  System error 64.  Verify that the file exists and that you can access it.
Check the textures folder to make sure the file exists, but you may need to recreate the deployment.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 18 of 22
Darin.Green
Bob and cstarr,
You both have something in common with your deployments. Both of you have spaces in your deployment path (deployment root directory):
\\hugo\Public\Revit 2014\Img\x64\RVT2014
Modify the deployment folders, shortcut paths and INI files to exclude the space a run the deployment again.
If this information was helpful, please consider using the Accept Solution
Message 19 of 22
kudzuman
It takes a little bit of scripting to automate but you could also specify Shared folder locations to a dummy folder on your C drive and then edit "C:\ProgramData\Autodesk\RVT 2014\UserDataCache\Revit.ini" replacing the dummy folder for your mapped network drive locations. Like replacing C:\Dummy\ in C:\Dummy\IES with Z:\Revit_2014\ to get Z:\Revit_2014\IES. You have to make sure you make the adjustment before anyone runs Revit on that computer.
You can't just switch it out for a Revit.ini file of your liking because the InstallGUID line may be different.
Message 20 of 22
hrm3
I'm not entirely sure what solved the issue but between using UNC paths in the deployment and taking the spaces out of the directory/file names, the deployment started working properly wihtout disabling UAC.
Thank you for your assitance.
Administrator Productivity
