Solved by TravisNave. Go to Solution.
If it works with your network disconnected, I would start there.
Here's what has always worked for me in these situations:
1. Disable Digital Signature Icons. Right-click your AutoCAD icon and it should be an option on your context menu. Uncheck the box, reboot.
2. Clear your %TEMP% folder. Delete everything in here that you can.
3. Check for mapped drives that are disconnected or invalid. Clear or fix these.
4. Check for offline or invalid network printers. Clear or fix these.
5. Run this registry fix (attached) that helps to ignore issues with broken links, invalid shortcuts, etc. I run this on every computer in my enterprise. You are welcomed to use it.
Generally speaking, following these steps usually creates a better overall experience with AutoCAD.
Good Luck!
I would have to think it is unique to your system. 2015, having been out for a year now, would have a widespread issue with this if it affected everyone. There must be some sort of conflict in particular with your system.
