Solved by DarrenP. Go to Solution.
Typically a home use exception is a stand-alone license, rather than a network seat. If approved, you should receive a 13-month stand-alone license for your product. However, someone from Autodesk will have to address this directly. This is a peer forum and as such, this is beyond the scope of friendly help.
heres how to request one: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17292987&linkID=9240617
DarrenP
HI Guyz
Thanks for advices. It helped and I filled in a form to request one home license. Now I'm waiting to response from Autodesk about that request.
greetings
Dawid Januszek
