Installation & Licensing
2340 Views, 3 Replies
AutoCAD on ThinClient
One my customer is planning to have Windows Server environment with Gigabit LAN. He plans to run AutoCAD 2007 from some 10 Thin Clients.
Can anybody suggest the AutoCAD2 2007 Product to be chosen for such setup? I think gigabit setup will remove any bottleneck of the data transfer between Server and Thin Clients. Also i will be highly obliged if somebody recommends server sizing keeping 10 thin clients in mind.
TIA
Vekarman
3 REPLIES 3
TravisNave
None. Using AutoCAD in this fashion violates the EULA.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Just search for "citrix" in all discussion groups.
We had the same problem - and decided for an other solution without autodesk: http://discussion.autodesk.com/thread.jspa?messageID=5013597
I'm curious - what other solution did you decide to use?
Administrator Productivity
