Autocad 2017.1 Update - Fatal Error
bvaneps
Message 1 of 8
bvaneps
I ran the updates that Autodesk Desktop App recommended for Revit and Autocad 2017.1. I now get an immediate crash and fatal error when opening 2017.1. OS: Windows7 and current. i7 4790k 32gb ram eVGA 970 (372.54 driver) Fatal Error: Unhandled Access Violation Reading 0x0008 Exception at b8e44bcah Application does not support just-in-time (JIT) debugging. See the end of this message for details. ************** Exception Text ************** System.Windows.Markup.XamlParseException: Set connectionId threw an exception. ---> System.InvalidCastException: Unable to cast object of type 'System.Windows.Controls.Grid' to type 'System.Windows.Controls.ContextMenu'. at Autodesk.AutoCAD.UserControls.DocumentSwitchControl.System.Windows.Markup.IComponentConnector.Connect(Int32 connectionId, Object target) at MS.Internal.Xaml.Runtime.ClrObjectRuntime.SetConnectionId(Object root, Int32 connectionId, Object instance) --- End of inner exception stack trace --- at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri) at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri) at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri) at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream) at Autodesk.AutoCAD.ViewModel.DocumentSwitch.DocumentSwitchServices.CreateDocumentSwitchControl() at Autodesk.AutoCAD.ViewModel.DocumentSwitch.DocumentSwitchServices.GetInstance() at Autodesk.AutoCAD.ViewModel.DocumentSwitch.DocumentSwitchServices.PlaceDocumentSwitchControl() at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke() ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll ---------------------------------------- Acdbmgd Assembly Version: 21.0.0.0 Win32 Version: 21.0.212.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcdbMgd.DLL ---------------------------------------- adui21 Assembly Version: 0.0.0.0 Win32 Version: 21.0.212.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/adui21.DLL ---------------------------------------- AdUiPalettes Assembly Version: 21.0.0.0 Win32 Version: 21.0.212.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdUiPalettes.DLL ---------------------------------------- WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- PresentationFramework Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll ---------------------------------------- PresentationCore Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll ---------------------------------------- System.Xaml Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll ---------------------------------------- AdApplicationFrame Assembly Version: 0.0.0.0 Win32 Version: 2015.11.2.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdApplicationFrame.DLL ---------------------------------------- AdWindows Assembly Version: 2016.5.0.0 Win32 Version: 2016.5.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdWindows.DLL ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- WindowsFormsIntegration Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll ---------------------------------------- PresentationFramework.Aero Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- accoremgd Assembly Version: 21.0.0.0 Win32 Version: 21.0.212.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/accoremgd.DLL ---------------------------------------- Acmgd Assembly Version: 21.0.0.0 Win32 Version: 21.0.212.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Acmgd.DLL ---------------------------------------- AcWindows Assembly Version: 21.0.0.0 Win32 Version: 21.0.212.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.DLL ---------------------------------------- AcWindows.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcWindows.resources.DLL ---------------------------------------- AcCui Assembly Version: 21.0.0.0 Win32 Version: 21.0.212.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCui.DLL ---------------------------------------- PresentationFramework-SystemXml Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- PresentationUI Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll ---------------------------------------- System.Xml.Linq Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll ---------------------------------------- PresentationFramework-SystemXmlLinq Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll ---------------------------------------- AcSeamless Assembly Version: 21.0.0.0 Win32 Version: 21.0.212.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcSeamless.DLL ---------------------------------------- Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- AcSeamless.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcSeamless.resources.DLL ---------------------------------------- BIM360GlueAutoCAD2017Addin Assembly Version: 4.37.6853.0 Win32 Version: 4.37.6853.0 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/BIM360GlueAutoCAD2017Addin.dll ---------------------------------------- BIM360GlueAddinsCommon Assembly Version: 4.37.6853.0 Win32 Version: 4.37.6853.0 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/BIM360GlueAddinsCommon.DLL ---------------------------------------- log4net Assembly Version: 1.2.11.0 Win32 Version: 1.2.11.0 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/log4net.DLL ---------------------------------------- FeaturedAppsPlugin Assembly Version: 21.0.0.0 Win32 Version: 21.0.46.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2017/Win64/FeaturedAppsPlugin.dll ---------------------------------------- PresentationFramework-SystemCore Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll ---------------------------------------- Anonymously Hosted DynamicMethods Assembly Assembly Version: 0.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll ---------------------------------------- UIAutomationTypes Assembly Version: 4.0.0.0 Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll ---------------------------------------- ContextualTabSelectorRules Assembly Version: 0.0.0.0 Win32 Version: 21.0.212.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.dll ---------------------------------------- Microsoft.Expression.Interactions Assembly Version: 4.0.0.0 Win32 Version: 2.0.20520.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Microsoft.Expression.Interactions.DLL ---------------------------------------- ************** JIT Debugging ************** Application does not support Windows Forms just-in-time (JIT) debugging. Contact the application author for more information.
Replies (7)
Message 2 of 8
TravisNave
My recommendation, as well as the recommendations of other Experts here, would be to uninstall the Desktop App and forego any updates unless you specifically require a fix that is provided by the update.  The mantra of "If it is not broken, don't fix it" holds very true.  Chances are, you will need to fresh install your AutoCAD again.  If you require manual updates in the future, due to a known issue, then update manually thru the support page.
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 8
TravisNave
In fact, this was one of the topics that @Mark.Lancaster and I brought up with Autodesk support during our AU meeting last week.  This is a growing concern.
Autodesk Forums:
Message 4 of 8
Lurifax
there is something wrong with the way the laguage pack is installed. This has nothing to do with hardware, AV, UAC etc.
If you install the language pack separately with a command similar to this (you can add paths, logging, silent etc.)
msiexec /p "acadLP_ENU.msp" REINSTALLMODE="ecmus" REINSTALL="ALL"
the fatal error goes away and all products work again. In my case AutoCAD 2017, Plant 3D and Civil 3D.
You have to extract the .msp files in computer that doesn have the update installed. (Why this behaviour beats me, it's annoying when testing)
i hope Autodesk could document all these little commands , tips and tricks for deployments and installations
Message 5 of 8
Lurifax
This is how I got the files extracted
Extract Files
AutoCAD_2017.1.1_Update_64bit.exe /e Files
Example:
dir Files /s
 Directory of C:\Packages\AutoCAD2017Upd11\Files\ExtractFiles
17.02.2017  11:39    <DIR>          .
17.02.2017  11:39    <DIR>          ..
03.11.2016  13:12       119 308 288 acad.msp
22.09.2016  07:55        30 941 184 acadLP_CHS.msp
22.09.2016  07:58        30 953 472 acadLP_CHT.msp
22.09.2016  05:11        30 867 456 acadLP_CSY.msp
22.09.2016  07:24        31 248 384 acadLP_DEU.msp
10.09.2016  02:14        29 237 248 acadLP_ENU.msp
22.09.2016  15:30        31 211 520 acadLP_ESP.msp
22.09.2016  07:45        31 232 000 acadLP_FRA.msp
23.09.2016  01:54        30 912 512 acadLP_HUN.msp
22.09.2016  07:48        31 199 232 acadLP_ITA.msp
22.09.2016  07:41        30 720 000 acadLP_JPN.msp
22.09.2016  08:02        30 687 232 acadLP_KOR.msp
22.09.2016  05:14        30 883 840 acadLP_PLK.msp
22.09.2016  07:51        31 203 328 acadLP_PTB.msp
23.09.2016  01:57        30 961 664 acadLP_RUS.msp
              15 File(s)    551 567 360 bytes
AutoCAD_Plant_3D_2017.1_Update.exe /e Files
dir Files /s
Directory of C:\Packages\Plant3D2017upd1\files\ExtractFiles
17.02.2017  12:01    <DIR>          .
17.02.2017  12:01    <DIR>          ..
30.09.2016  01:00        17 637 376 PLNT3D.msp
30.09.2016  00:52         3 670 016 PLNT3DLP.msp
30.09.2016  01:03         5 201 920 PLNT3DPS.msp
               3 File(s)     26 509 312 bytes
Juha
Message 6 of 8
freesbee
AutoCAD 2017 Unhandled Access Violation Reading 0x0008 Exception at 9ff4bcah
[SYMPTOMS]
When installing a language pack on top of an AutoCAD verticalization (Mechanical, Architectural...) already with an update, and you try to start the product of Language Packed version, AutoCAD first gives an error like this one:
 and then crashes with an error similar to this one:AutoCAD_ERR02.PNG
while the core language still works fine (for "core language" I mean the language of the initial installation).
[FIX]
It appears to be a known issue, but I haven't found any reference to the specific error, so I'm writing it here and maybe other users will save time.
You don't need to reinstall AutoCAD (that's the long solution for people with a lot of time and not many installations to manage).
The issue gets solved if the update is reinstalled after installing the Language Pack.
I am not talking about the "AutoCAD 2017 Service Pack 1". The right update to reinstall is the
AutoCAD 2017 Service Pack 1.1
that can be downloaded via subscription account (about 450 MBytes file).
After that action also the AutoCAD and its verticalizations will work properly even in the language pack version.
Of course, if you install multiple language packs, then install the update after the last one.
Hope it helps Smiley Wink
Massimo Frison
CAD R&D // PDM Admin · Hekuma GmbH
Message 7 of 8
freesbee
To completeness of the information it is important to mention that alternatively, "Control Panel / Programs and Features / View Installed updates" selecting "AutoCAD 2017.1.1 Update > Change" and clicking on "Repair" has the same effect:Err03.PNG
After either or action also the AutoCAD and its verticalizations will work properly even in the language pack version.
Hope that it helps, but kudos are always welcome Smiley Wink
Massimo Frison
Message 8 of 8
BIMologist_
I uninstalled the Update 2017.1.2 and just reinstalled it and it started running fine. No full uninstall needed!! thanks
BIMologist
- Nauman Mysorewala
Did you find this post
helpful? Feel free to like this post.
Did your question get successfully answered? Then click
on the ACCEPT SOLUTION button.
