i had installed Auto CAD LT 2010 on an Windows XP 32 BIT Version.
The Software runs over a long time. Now i have a problem.
Autocad can't start.
I see the grey screen and then close the Programm.
I see no error message.
So i have remove the software and then i have installed new, but the same problem.
On an other PC i have the same Windows Version and the same XP Updates.
On this other PC runs the AutoCad LT 2010 corretctly without error.
Can everyone help me ?????
Sorry for my bad Englisch !
Regard
Please understand that July 4th is Independence Day in the United States, so you were unlikely to get any activity on the boards yesterday for the holiday.
As for your AutoCAD, you may try launching the software as another user (local Administrator, for example.)
sorry i don't know that yesterday was the Indeoendence Day. I had install the software as local admin. I think the problem is, when i remove the software then not all entry's blank in the registry.
But i don't know witch autocad entry's in the registry i can remove.
Regard
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
thanks for your help. Tomorrow i will try it again. Maybe is this the solution.
Regard
so i had all Autodesk Software removed from the PC. (KB from Autodesk)
I had all Entry's in the Registry with "Autocad" and "Autodesk" and "LT2010" removed.
Then Restart.
I installed the Autocad LT 2010 Sofware and had the same Problem.
I start the Programm and see the grey Screen from the Program.
After 10 second the program closed without an error message.
What can I do ????
I need a error message or who is a log file for the program ?
I don't know what i can do now.
On other PC runs corretly.
Regard
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For all other installation problems consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
also the Autocad 2010LT run's not. The Instalation is o.k..no error.
I see the screen (in the attatchmend word dokument)
But after 10 second the Autodesk closed without error message.
I installed and removed the program now very often.
Grafic driver is the newest, and net framework 3.5 SP1 is also new installed.
Regards
Autocad isn't a good software.
A good software send me a error message or i have a log file. Then i can
see what is the problem.
What is the reason thats the program can't start.
Display Driver ????????
Net Framework ??????
hidden entry in the registry ????
Witch entrys in the registry i have to delete ???????
Questions over Question
It's a terrible software and no people have an idea.
Regards
