Strange indeed. I am not a big fan of the redundant license server setup for a number of reasons. From the clients, can you ping each of the license servers? Are you using the ADSKFLEX_LICENSE_FILE and FLEXLM_TIMEOUT system environment variables? Also have you verified that all three license servers are running and communicating with each other? As an additional network test, try turning your NIC down to 10/Half and see if the application launches any faster.
