Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Anyone try Windows 8 Developer preview?
67 REPLIES 67
Message 1 of 68
pendean
23858 Views, 67 Replies
Or have plans to try the public Beta of Windows 8 to be released soon?
I had greate success with the Win7 beta and wondering if Windows8 will be the same experience.
67 REPLIES 67
Message 21 of 68
TravisNave
What is your video card and driver?  Does AutoCAD fail to run after this error?
Autodesk Forums:
Message 22 of 68
in reply to: TravisNave
My card is Radeon HD 6770 , Driver on web of ATi was update date new version . I was use on win 7 , not erro ...
If click Ok erro , it dis to windows 😞
Message 23 of 68
Ah , I know reasons, this is driver graphic card of win 8 . I was reinstall driver on ATi's web, it work , but after update driver on win 8 , it erro 🙂
Message 24 of 68
TravisNave
Excellent.  That's kinda what I figured was the problem.  I am not a fan of ATI drivers at all.
ATI = Always Trashes Inventor.  Smiley Very Happy
Autodesk Forums:
Message 25 of 68
When will Autodesk 2013 be release ? Smiley Happy
Message 26 of 68
TravisNave
in reply to: pendean
You know we're not allowed to tell. 😉
Soon!
Autodesk Forums:
Message 27 of 68
Just tell me a little bit ,ok ! he he ;))
Message 28 of 68
pendean
After R2009 upgrade window/period dies (currently slated for March 15): historically that's been the case, not sure they plan on changing.
This was tweeted yesterday, no mention of Win8 of course:
Lynn_Allen #AutoCAD 2013 System Requirements http://t.co/D6Dmw6nu (http://inventortopix.blogspot.in/2012/03/autocad-2013-system-requirements.html)
Message 29 of 68
Waiting Waiting ... 🙂
But why not support Win8 and Framework 4.5 😞
Message 30 of 68
With all due respect, your fix doesn't work.
First, I should tell you that I have Windows 8 and Autocad 2012 with a downloaded zip file from Autodesk.
Second, my error message is for the .net frameowork, which I assume is because 4.5 is part of the new operating system and it won't allow any installation of 4.0.  I tried installing 4. directly from Microsoft, but that wasn't allowed either.
This is what I did:
1. I deleted all the dot 4 references. That didn't work.
2. I replaced your setup.ini file that you provided in the thread with the original, but that didn't work.
3. After I realized that when the program is unzipping, it replaces the setup.ini file that I changed back to the original one, so I waited until it stopped unzipping to replace it.  That didn't work.
Are there two setup.ini files?
 But I doubt that is the problem.  I am getting the setup.ini file in the main folder of the Archicad file.  It is right under the setup.exe file.
4.  I  tried using every compatibility settings going back to XP.  That didn't work.
Lastly, I have played with turning on and off the .net framework programs, but that doesn't worh either.
Message 31 of 68
TravisNave
Respectfully, it does work as I have done it as well as others using this method.  Please understand that Windows 8 is in beta and is not a supported OS for Autodesk products.  If this process did not work for you, perhaps there are other details that are preventing you from installing the software or you are missing a key step in the process.  There is no guarantee that the application will install.  I am simply providing the method that worked for me after many trials.
Autodesk Forums:
Message 32 of 68
dgorsman
The words "Developer preview" in the actual title not enough of a clue??
Message 33 of 68
After fiddling with it some more and editing parts of the setup.ini code that were creating some problems, I did get it to install.
Unforunately, Autocad seems really buggy and unstable in the new OS, but I guess beggars can't be choosers.
I'm sorry if I jumped the gun earlier, because your fix does work with a couple adjustments.
Message 34 of 68
TravisNave
No hard feelings - we're all here to help each other. I'm sure Autodesk will approve Windows 8 for a future release and these problems will be a thing of the past.
Autodesk Forums:
Message 35 of 68
FYI, just tried on the Windows 8 Release Preview and was able to use the original steps to install both  Civil3D 2012 succesfully (content server for C3D didn't install but I don't use it anyway).
Civil3D 2013 installed without any problems.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Message 36 of 68
pendean
in reply to: michael_robertson
Nice: I'm about to try the same this weekend with R2013.
Message 37 of 68
DarrenP
the question is will the autodesk products be wrtten for the metro ui
DarrenP
Message 38 of 68
pendean
in reply to: DarrenP
Message 39 of 68
DarrenP
i hope it does
DarrenP
Message 40 of 68
michael_robertson
It's not getting pulled, the Release Preview is pretty much what is coming out later this year to manufacturing. I didn't like it at first but as I've used it I've become used to it and they've made many changes in the Release Preview that weren't in the Developer & Consumer previews.
Mike Robertson
Administrator Productivity
