I recently did a test run with network license manager with a valid license key. All went well, and I was wondering if I need to free up the product key and serial number used to do the test run.
Help is appreciated.
Thomas
Solved by TravisNave. Go to Solution.
Nah, you shouldn't need it. If you are going to have a newer license manager and/or file, you can just configure it as needed. The license manager itself handles the licensing, so there is nothing to free up if you no longer use it. Hope that makes sense.
It indeed does make sense. Thank you Travis. I will let you know if all goes well. I am doing the installs this week.
Just post in the Licensing forum if you run into anything. I'll most likely see it in there.
