Have tried several times to down load ??
New lap top with allsystem requirements. Had no problems loading auto cad but can't get Maya to download.
013/12/26:14:46:57 SDalziel5 STUARTDALZIEL === Setup started on STUARTDALZIEL by SDalziel5 ===
2013/12/26:14:46:57 SDalziel5 STUARTDALZIEL Path_Length: 151
2013/12/26:14:46:57 SDalziel5 STUARTDALZIEL Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2013/12/26:14:46:57 SDalziel5 STUARTDALZIEL Launch
2013/12/26:14:46:57 SDalziel5 STUARTDALZIEL CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-43822430 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2013/12/26:14:46:57 SDalziel5 STUARTDALZIEL Current Directory C:\Users\SDALZI~1\AppData\Local\Temp\_AIBE08.tmp
2013/12/26:14:47:00 SDalziel5 STUARTDALZIEL === Setup ended ===
2013/12/26:14:46:58 SDalziel5 STUARTDALZIEL === Setup started on STUARTDALZIEL by SDalziel5 ===
2013/12/26:14:46:58 SDalziel5 STUARTDALZIEL Path_Length: 151
2013/12/26:14:46:58 SDalziel5 STUARTDALZIEL Current Directory C:\Users\SDALZI~1\AppData\Local\Temp\_AIBE08.tmp
2013/12/26:14:46:58 SDalziel5 STUARTDALZIEL Launch
2013/12/26:14:47:00 SDalziel5 STUARTDALZIEL Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2013/12/26:14:47:00 SDalziel5 STUARTDALZIEL PageOpen LaunchDialog
2013/12/26:14:47:09 SDalziel5 STUARTDALZIEL PageOpen LicenseDialog
2013/12/26:14:47:14 SDalziel5 STUARTDALZIEL PageOpen ProductInfoDialog
2013/12/26:14:47:14 SDalziel5 STUARTDALZIEL PageOpen ProductSelectionDialog2
2013/12/26:14:47:16 SDalziel5 STUARTDALZIEL PageOpen FullProgressDialog
2013/12/26:14:47:16 SDalziel5 STUARTDALZIEL Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2013/12/26:14:47:16 SDalziel5 STUARTDALZIEL Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/12/26:14:47:42 SDalziel5 STUARTDALZIEL Install DirectX® Runtime Succeeded
2013/12/26:14:47:42 SDalziel5 STUARTDALZIEL Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2013/12/26:14:53:20 SDalziel5 STUARTDALZIEL Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2013/12/26:14:53:20 SDalziel5 STUARTDALZIEL Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/12/26:14:53:20 SDalziel5 STUARTDALZIEL Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
The downloads lately have been problematic. You might instead try downloading from the virtual agent. Others who have had your identical problem have had success this way:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
@Anonymous wrote:
I just tried this and it did not work for me.
Error
Setup.exe - Bad Image
C:Windows\System32\MSVCP100.dll is either not design to run on windows or it contains an error.
I can download the file no problem, but I can't seem to install it.
You might edit the setup.ini to remove the check for Visual C++.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Installation-aborted/m-p/3873491
Do I have to download http://www.microsoft.com/en-us/download/details.aspx?id=3324 to follow this steps?
Unlikely. Just modify the setup.ini to remove the prerequisite or to ignore it. Here's another resource of mine to explain it:
