Installation & Licensing
Unable to Uninstall Autodesk Revit Architecture 2014
11 REPLIES 11
Message 1 of 12
daley1234
8467 Views, 11 Replies
I am trying to install Autodesk Revit Architecture 2014 but it tells me that it is already installed. I had a previous installation removed but apparently it was not removed entirely. I tried using the Autodesk Uninstall tool to removed it but that also failed. I have attached a print screen with the view that is shows when it fails.
Does anyone know of a tool that can be used to removed it so I can reinstall the products?
11 REPLIES 11
Message 2 of 12
DannyHubbard
in reply to: daley1234
You should be able to remove the product using the Microsoft Fix It utility.
http://support.microsoft.com/mats/Program_Install_and_Uninstall
Danny
Danny Hubbard
QA Analyst
Message 3 of 12
daley1234
I tried the tool but it did not find Revit installed. I have check just about every registry key that has revit on them and deleted them however, the installer is still telling me that revit is installed.
I do not know what else to do.
Message 4 of 12
pendean
Did you manually delete The program folders too?
What if you just accept the findings and continue with the Ibstallation, then follow it with a full "repair" reinstall?
Try using a registry cleaner first, then restart Windows after the cleaner stops findings issues. I like CCLEANER myself but there are others.out there.
Message 5 of 12
daley1234
in reply to: pendean
The installation cannot go any further, its either back or cancel. The
program is not on the machine so it cannot be repaired.
Message 6 of 12
TravisNave
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
I have not tested the MSICUU2.exe on Windows 8 yet.  Could be disasterous...
Autodesk Forums:
Message 7 of 12
dembkod
daley1234,
Hello. You could delete these two registry keys. These are the main Revit Architecture keys that would cause your issue:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\0A4B643700410110000007C5D0680240
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\0A4B643700411110409007C5D0680240
Thank you for taking part in our community!
David Dembkoski
Message 8 of 12
daley1234
in reply to: TravisNave
I installed the tool and ran it but it did not find the software on the machine.
Message 9 of 12
daley1234
in reply to: dembkod
I deleted the two registry keys and I was able to restart the set-up process. Thanks a million.
Message 10 of 12
bbrown
I had the same issue and deleting the registry keys fixed it for me as well. Took forever to find this post. Thank you!
Message 11 of 12
Hey
Where can I find these keys ? I have the same issue but with REvit structure can't uninstall it
thank you
Message 12 of 12
bbrown
You need to edit those keys in the registry. Here is an article showing how to open and edit the registry: http://www.wikihow.com/Edit-the-Windows-Registry
Administrator Productivity
