I have installed Inventor and have been able to retrieve my student license key and serial number. However, when I try to activate the software from within the application, I get a GUI window that is mostly blank, although there are two radio buttons just barely visible in the top left corner. This window appears after I agree to the Terms of Service and click to the next window.
I have also attempted to activate online, but this process requires a "request code", which I presume would be displayed during the in-application activation process, if the GUI wasn't broken. A screenshot is attached. Any ideas how to fix the GUI, or can I activate another way? Thanks in advance for your assistance.
-Maurice
Similar Problem in this thread:
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
