Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Licensings erver for AutoCAD 2011
- Highlight
- Email to a Friend
Hi.
We are currently in a situation where our AutoCAD licensing server has to be moved, and upgraded to support the latest version.
As far as I know we have a 10 user limit license.
A few weeks ago I received the new AutoCAD 2011 DVD in the mail and my questions are basically... What do I do? Where do I start?
I am totally new to AutoCAD and I am reluctant to spend too much time and effort on it, so hopefully I can get some good starting pointers here ![]()
Re: Licensings erver for AutoCAD 2011
- Highlight
- Email to a Friend
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Licensings erver for AutoCAD 2011
- Highlight
- Email to a Friend
Hi.
How should I go about moving the current license server? From what I can remember we tried this once before without any sucsess.
- Highlight
- Email to a Friend
You're not really going to move it, per se. The LIC file on the old server won't work on the new one. All you really need to do is install the license manager from your 2011 media on the new server and get the license file from Autodesk Activations.
Then you can install your clients and point to the new server. It's easier than you think.
If there's anything you get stuck on just let me know.
- Highlight
- Email to a Friend
Thanks for your help, i deeply appreciate it!
- Highlight
- Email to a Friend
Yes. The NLM is backwards compatible to version 9.2, which I believe is AutoCAD 2004 if my memory serves correct. If your 2011 product is under Subscription, your new subscription license file should allow for use of AutoCAD 2008, 2009, 2010, and 2011.
Autodesk does provide a too long explanation how-to video on the NLM here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
