Installation & Licensing
Installed & registered - now what?
4 REPLIES 4
381 Views, 4 Replies
Have AutoCad 2010.
Have setup the deploymment.
Installed the license manager and have registered the installation.
But now what? As I recall from the past, I needed to get the license file from you. I haven't received any such file that I know of.
What do we need to do next?
Looking forward to your response. Thanks.
4 REPLIES 4
TravisNave
If your client was installed and activated successfully, then you have a stand-alone license type. You do not need a license file from Autodesk. Does your client software work?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
No, the software doesn't work - I get a 'valid license could not be obtained by the network license manager' message when starting the installed deployment.
We're using a single license server model for the network license.
In the past I've had to / gotten a license file from you. That what I need now?
Thanks for the response. thanks.
TravisNave
Ha! You haven't gotten it from me, my friend. I am not Autodesk.
But indeed, you do need an updated license file for your product. Call Autodesk Activations at 1-800-551-1490 and press #1 for English and #2 for network licensing. They will provide you the license file that you need. Good luck!
Autodesk Forums:
OK, your right - probably not from you - I can't remember from year to year how this works.
anyway, contacted AutoDesk and obtained the file - all is OK.
Thanks.
Administrator Productivity
