• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Installation of maya 2013 failed! please help!
    409 Views, 1 Replies
    01-16-2013 08:29 AM
    since i installed windows 7 on my new ssd( i deleted of course the old) i can't install maya 2013! Everytime i try to install it appears a message " Communication failure" no of the three download methods worked!
    here is the log:
    2013/1/14:20:46:49    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
    2013/1/14:20:46:49    Manuel    ARTICMASTER    Launch
    2013/1/14:20:46:51    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/14:20:46:51    Manuel    ARTICMASTER    PageOpen    LaunchDialog
    2013/1/14:20:46:53    Manuel    ARTICMASTER    PageOpen    LicenseDialog
    2013/1/14:20:46:56    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
    2013/1/14:20:48:45    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
    2013/1/14:20:49:34    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
    2013/1/14:20:49:34    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Program Files (x86)\Autodesk 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2013/1/14:20:49:34    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
    2013/1/14:20:49:35    Manuel    ARTICMASTER    PageOpen    InstallCompleteDialog
    2013/1/14:20:49:40    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/14:20:59:31    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
    2013/1/14:20:59:31    Manuel    ARTICMASTER    Launch
    2013/1/14:20:59:33    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/14:20:59:32    Manuel    ARTICMASTER    PageOpen    LaunchDialog
    2013/1/14:20:59:34    Manuel    ARTICMASTER    PageOpen    LicenseDialog
    2013/1/14:20:59:37    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
    2013/1/14:21:01:11    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
    2013/1/14:21:01:32    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
    2013/1/14:21:01:32    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Program Files (x86)\Autodesk 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2013/1/14:21:01:32    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
    2013/1/14:21:01:33    Manuel    ARTICMASTER    PageOpen    InstallCompleteDialog
    2013/1/14:21:01:41    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/14:21:23:21    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
    2013/1/14:21:23:21    Manuel    ARTICMASTER    Launch
    2013/1/14:21:23:24    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/14:21:23:24    Manuel    ARTICMASTER    PageOpen    LaunchDialog
    2013/1/14:21:23:33    Manuel    ARTICMASTER    PageOpen    LicenseDialog
    2013/1/14:21:23:43    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
    2013/1/14:21:25:16    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
    2013/1/14:21:25:25    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
    2013/1/14:21:25:25    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Program Files (x86)\Autodesk 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2013/1/14:21:25:26    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
    2013/1/14:21:25:26    Manuel    ARTICMASTER    PageOpen    InstallCompleteDialog
    2013/1/14:21:25:30    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/16:16:21:41    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
    2013/1/16:16:21:41    Manuel    ARTICMASTER    Launch
    2013/1/16:16:21:43    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/16:16:21:43    Manuel    ARTICMASTER    PageOpen    LaunchDialog
    2013/1/16:16:21:44    Manuel    ARTICMASTER    PageOpen    LicenseDialog
    2013/1/16:16:21:52    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
    2013/1/16:16:23:30    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
    2013/1/16:16:23:41    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
    2013/1/16:16:23:41    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2013/1/16:16:23:42    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
    2013/1/16:16:23:42    Manuel    ARTICMASTER    PageOpen    InstallCompleteDialog
    2013/1/16:16:23:46    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/16:16:34:53    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
    2013/1/16:16:34:53    Manuel    ARTICMASTER    Launch
    2013/1/16:16:34:55    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/16:16:35:29    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
    2013/1/16:16:35:29    Manuel    ARTICMASTER    Launch
    2013/1/16:16:35:33    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/16:16:35:30    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
    2013/1/16:16:35:30    Manuel    ARTICMASTER    Launch
    2013/1/16:16:35:33    Manuel    ARTICMASTER    PageOpen    LaunchDialog
    2013/1/16:16:35:35    Manuel    ARTICMASTER    PageOpen    LicenseDialog
    2013/1/16:16:35:43    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
    2013/1/16:16:37:18    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
    2013/1/16:16:37:39    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
    2013/1/16:16:37:40    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Manuel\Downloads\Autodesk Maya 2013 x64\Autodesk Maya 2013 x64\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2013/1/16:16:37:40    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
    2013/1/16:16:37:41    Manuel    ARTICMASTER    PageOpen    InstallCompleteDialog
    2013/1/16:16:37:44    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/16:16:54:02    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
    2013/1/16:16:54:02    Manuel    ARTICMASTER    Launch
    2013/1/16:16:54:04    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/16:16:54:03    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
    2013/1/16:16:54:03    Manuel    ARTICMASTER    Launch
    2013/1/16:16:54:04    Manuel    ARTICMASTER    PageOpen    LaunchDialog
    2013/1/16:16:54:07    Manuel    ARTICMASTER    PageOpen    LicenseDialog
    2013/1/16:16:54:10    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
    2013/1/16:16:54:17    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
    2013/1/16:16:54:18    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
    2013/1/16:16:54:19    Manuel    ARTICMASTER    Installing Autodesk® MatchMover™ 2013:   INSTALLDIR="H:\Program Files\Autodesk\MatchMover2013\"  ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\" INSTALLDIR="H:\Program Files\Autodesk\MatchMover2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2013/1/16:16:54:38    Manuel    ARTICMASTER    Install    Autodesk® MatchMover™ 2013    Succeeded
    2013/1/16:16:54:38    Manuel    ARTICMASTER    Installing Autodesk® Maya® Composite 2013:   INSTALLDIR="H:\Program Files\Autodesk\Composite 2013\"  ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\" INSTALLDIR="H:\Program Files\Autodesk\Composite 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2013/1/16:16:55:14    Manuel    ARTICMASTER    Install    Autodesk® Maya® Composite 2013    Succeeded
    2013/1/16:16:55:14    Manuel    ARTICMASTER    Installing Autodesk® Backburner 2013: E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\x64\BackBurner\BackburnerCIF.exe
    2013/1/16:16:55:21    Manuel    ARTICMASTER    Install    Autodesk® Backburner 2013    Succeeded
    2013/1/16:16:55:21    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Manuel\Documents\3ds Max\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2013/1/16:16:55:22    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
    2013/1/16:16:55:22    Manuel    ARTICMASTER    Rollback    Autodesk® Backburner 2013    Failed    Failure is ignored, Result=1619
    2013/1/16:16:56:02    Manuel    ARTICMASTER    Rollback    Autodesk® Maya® Composite 2013    Succeeded
    2013/1/16:16:56:31    Manuel    ARTICMASTER    Rollback    Autodesk® MatchMover™ 2013    Succeeded
    2013/1/16:16:56:31    Manuel    ARTICMASTER    PageOpen    InstallCompleteDialog
    2013/1/16:16:56:40    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/16:17:11:49    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
    2013/1/16:17:11:49    Manuel    ARTICMASTER    Launch
    2013/1/16:17:11:49    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/16:17:11:49    Manuel    ARTICMASTER    PageOpen    MaintenanceDialog
    2013/1/16:17:11:51    Manuel    ARTICMASTER    PageOpen    MaintVerifyReadyDialog
    2013/1/16:17:11:53    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
    2013/1/16:17:11:53    Manuel    ARTICMASTER    Installing Autodesk® Maya® 2013:  REMOVE=ALL INSTALLDIR="H:\Program Files\Autodesk\Maya2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2013/1/16:17:13:55    Manuel    ARTICMASTER    Uninstall    Autodesk® Maya® 2013    Succeeded
    2013/1/16:17:13:55    Manuel    ARTICMASTER    PageOpen    MaintCompleteDialog
    2013/1/16:17:13:59    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/16:17:17:59    Manuel    ARTICMASTER    === Setup started on ARTICMASTER by Manuel ===
    2013/1/16:17:17:59    Manuel    ARTICMASTER    Launch
    2013/1/16:17:18:01    Manuel    ARTICMASTER    === Setup ended ===
    2013/1/16:17:18:01    Manuel    ARTICMASTER    PageOpen    LaunchDialog
    2013/1/16:17:18:05    Manuel    ARTICMASTER    PageOpen    BeginDeploymentDialog
    2013/1/16:17:18:13    Manuel    ARTICMASTER    PageOpen    LaunchDialog
    2013/1/16:17:18:21    Manuel    ARTICMASTER    PageOpen    LicenseDialog
    2013/1/16:17:18:40    Manuel    ARTICMASTER    PageOpen    ProductInfoDialog
    2013/1/16:17:20:05    Manuel    ARTICMASTER    PageOpen    ProductSelectionDialog2
    2013/1/16:17:20:24    Manuel    ARTICMASTER    PageOpen    FullProgressDialog
    2013/1/16:17:20:24    Manuel    ARTICMASTER    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\Program Files (x86)\Autodesk Maya 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:H:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v E:\Manuel\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2013/1/16:17:20:25    Manuel    ARTICMASTER    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1603
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Installation of maya 2013 failed! please help!
    01-16-2013 10:32 AM in reply to: manuel.galliker
    Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
    For more information about this process, please see my KB link here:
    http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
    You might consider downloading and installing this update directly from Microsoft as well.
    Good Luck!
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
