When installing Autodesk DWG TrueView 2014 on Windows 7 32-bit, I get a message about not finding the EULA. At the point where I click "Install On This Computer" I get a DWG Trueview 2014 window with the message "Can't Find End User License Agreement" my only option is to click ok which closes the install.
I hope someone can help, I've installed this software multiple times and have never ran across this.
I still receive the same issue. The first time I tried it this morning it allowed me to accept the EULA but the install failed. After I retried the EULA doesnt come up again
See if you can physically find the EULA file and move it to where it is expected.
Hi Jorge,
Do you experience the same behavior if you bypass the download manager and utilize a direct DWG TrueView 2014 download link?
The EULA is in C:\Autodesk\SetupDWGTrueView2014_ENU_32bit\EULA folder, should it be somewhere else? I checked the minimum system requirements and it meets all. I'm running Office 2003, could that be the issue? The EULA is saved as a Word doc
And you are not installing outside of your region or with a foreign OS or language, correct?
I was able to successfully install the software
I opened the Setup.ini document and found a line about the EULA.
EULA_PATH=EULA
Changed it to the correct path
EULA_PATH=C:\Autodesk\SetupDWGTrueView2014_ENU_32bit\EULA
Saved the file and the install worked!
Thanks for the help
Excellent job!
@Anonymous
Welcome to the community...
This posting is 2 years old...
"i don't fine Desktop.ini file. where to fine it?" Doesn't really mean a lot to us. Give us details of what Autodesk product and version you are trying to install or what you're trying to accomplish here.
Mark Lancaster
& Autodesk Services MarketPlace Provider
