I have some problems with the installing of AutoCAD 2013 student version. I am using win 8 now. And I think it's about .NET. However, I tried to install .NET 4 or .NET 4.5 from MS, both failed.
Here is the log file:
2013/1/8:19:05:33 Cs CS-IDEA-PC === Setup started on CS-IDEA-PC by Cs ===
2013/1/8:19:05:33 Cs CS-IDEA-PC Launch
2013/1/8:19:05:35 Cs CS-IDEA-PC PageOpen LaunchDialog
2013/1/8:19:05:36 Cs CS-IDEA-PC PageOpen LicenseDialog
2013/1/8:19:05:38 Cs CS-IDEA-PC PageOpen ProductInfoDialog
2013/1/8:19:06:21 Cs CS-IDEA-PC PageOpen ProductSelectionDialog2
2013/1/8:19:06:27 Cs CS-IDEA-PC PageOpen FullProgressDialog
2013/1/8:19:06:27 Cs CS-IDEA-PC Installing .NET Framework Runtime 4.0 Language Pack: E:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_2052.exe /q
2013/1/8:19:06:33 Cs CS-IDEA-PC Install .NET Framework Runtime 4.0 Language Pack Failed Installation aborted, Result=1603
Solved by TravisNave. Go to Solution.
Have you tried checking that:
Do you have any other Autodesk products currently installed?
There is a known issue regarding a bug when you try to install AutoCAD with SP1.1 at the same time. See the Up & Ready blog post http://upandready.typepad.com/up_and_ready/2012/10/error-ngenexe-and-installing-any-autocad-product....
I hope this helps,
Jennifer Hoskens
The reason it failed on Windows 8 is because it is looking to install .NET Framework 4.0 which is already preinstalled and newer on the Win 8 OS. Windows 8 is not a supported OS for your installation. You can however, get it installed by modifying the setup.ini to remove the prerequisite installer for .NET 4.0.
Error1603 ; PLEASE HELP
2014/3/10:14:01:57 Auto-Cad CAD-1 === Setup started on CAD-1 by Auto-Cad ===
2014/3/10:14:01:57 Auto-Cad CAD-1 Launch
2014/3/10:14:02:44 Auto-Cad CAD-1 PageOpen LaunchDialog
2014/3/10:14:03:34 Auto-Cad CAD-1 PageOpen LicenseDialog
2014/3/10:14:03:37 Auto-Cad CAD-1 PageOpen ProductInfoDialog
2014/3/10:14:07:59 Auto-Cad CAD-1 PageOpen ProductSelectionDialog2
2014/3/10:14:08:43 Auto-Cad CAD-1 PageOpen FullProgressDialog
2014/3/10:14:08:43 Auto-Cad CAD-1 Installing DirectX® Runtime: L:\SAA AUTODESK\Autodesk BDSP 2013\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\DirectX\DXSETUP.exe /silent
2014/3/10:14:17:37 Auto-Cad CAD-1 Install DirectX® Runtime Succeeded
2014/3/10:14:17:37 Auto-Cad CAD-1 Installing FaroSDK: L:\SAA AUTODESK\Autodesk BDSP 2013\Building_Design_Suite_Prm_2013_English_px86x64\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
2014/3/10:14:17:48 Auto-Cad CAD-1 Install FaroSDK Succeeded
2014/3/10:14:17:50 Auto-Cad CAD-1 Installing AutoCAD® 2013: TRANSFORMS="L:\SAA AUTODESK\Autodesk BDSP 2013\Building_Design_Suite_Prm_2013_English_px86x64\x64\en-us\acad\acad.mst;C:\Users\Auto-Cad\AppData\Local\Temp\_AIB634.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="L:\SAA AUTODESK\Autodesk BDSP 2013\Building_Design_Suite_Prm_2013_English_px86x64\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/3/10:14:19:39 Auto-Cad CAD-1 Install AutoCAD® 2013 Failed Installation aborted, Result=1603
2014/3/10:14:19:39 Auto-Cad CAD-1 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
