Thanks for the reply,
I can ping the server no problem and I can run it under any user but Gust
account.
This is the LicenseErrorLog.txt just in case somebody knows anything about
it.
3852 2006/12/21 09:53:24 Reason=Fatal error
3852 2006/12/21 09:53:24 ComputerName=XYZ
3852 2006/12/21 09:53:24 OS=5.1.2600 Service Pack 2
3852 2006/12/21 09:53:24 File=FlmModelHandler.cpp,Line=530
3852 2006/12/21 09:53:24 AdlmError=1
3852 2006/12/21 09:53:24 VendorID=5
3852 2006/12/21 09:53:24 VendorError=-5
Thanks again
"Henrik Goldman" wrote in message
news:5432654@discussion.autodesk.com...
Hi Keyvan,
> It runs fine under any user except Guest account, even if I make it
> Administrator. it comes up with error 1.5, -5, and can not get license,
> otherwise it works fine and get license. (under any user but Guest Account
> even with administrative right..
You should make sure that you are able to ping the license server. It's most
likely since you lost the path for the license server.
One try would be to set the environment variable like this (before running
the application):
LM_LICENSE_FILE = @server
Best Regards,
Henrik Goldman
Track your flexlm licenses and reduce your costs -
http://www.x-formation.com/license_statistics/index.html
Our licensing and software security blog -
http://www.x-formation.com/security_blog/
Protect your software - http://www.x-formation.com/LM-X
