We are looking to deploy AutoDesk products to a number of our remote sites via SCCM.
I have read the documentation on this and have a question on its functionality:
While creating the deployment, the adminimage location is specified. When this is created in our environment, it is done on storage at our primary site. This application is then distributed to remote SCCM servers.
At the time that this is run from the remote SCCM servers, where will the installation pull needed files from? I noted that the installation specifies that the adminimage is back at our primary site - does this indicate that it will pull the entire installation from this location. In our case, this would mean it would be pulling the application back over our slow link between the primary and remote site which would have obvious negative effects.
Do I need to create/manage seperate builds for each remote site?
Thanks for any input,
-Jake
You'd be better off having a deployment created locally at each site. You don't wanna push multiple gigs out to your stations across the WAN.
