We have a client that is getting a bunch of new systems and each of them will require AutoCad Civil 3D Imperial 2010. We will be deploying these machines via a master image and using Microsoft SysPrep on them.
What we want to know is can we include in the master build an install of AutoCad or will that require seperate installs afterwords?
If your seats are network licensed, then you can include them in the image. If they are stand-alone licensed, then you must install them afterwards.
Is there docuentation somewhere on packaging AutoCad 2010 Civil 3D for an unattended install?
Yes there should be documentation on your media. Or you can do a search on the forums if you need to find additional information.
