I have been having this exact problem for the past week. For some strange
reason, it fixed itself today. All I did was step through the deployment
wizard again, as I have several times in the past week. For whatever
reason, this time was magical. The only thing I can think of is that there
must have been some network condition that contributed to this. Don't ask
me what, though...
Jon
wrote in message news:4839125@discussion.autodesk.com...
I am having problem with client deployment of AutoCAD 2006. It starts but
after seeing "Installing DWG viewer.." it just quits.
When I look at the log file it shows the following:
Anyone has any idea ? Thanks in advance for any reply.
5/9/2005 15:04:00] === Installation started on JOHN by JOHN ===
[5/9/2005 15:04:00] [Info] Windows Installer upgrade is not required
[5/9/2005 15:04:00] System Version = 3.1.4000.1823
[5/9/2005 15:04:00] Installation skipped: MSI Runtime 3.0
[5/9/2005 15:04:00] [Info] .NET Framework Runtime upgrade is not required
[5/9/2005 15:04:00] System Version = 1.1.4322.2032
[5/9/2005 15:04:00] Installation skipped: .NET Framework Runtime 1.1
[5/9/2005 15:04:00] Installation skipped: .NET Framework Runtime 1.1 SP1
[5/9/2005 15:04:00] [Info] MDAC upgrade is not required
[5/9/2005 15:04:00] System Version = 2.81.1117.0
[5/9/2005 15:04:00] Installation skipped: MDAC 2.7
[5/9/2005 15:04:00] Installation started: Autodesk DWF Viewer
[5/9/2005 15:04:00] Command = "\\Jan\c\acad
2006\AdminImage\support\aev\DWFViewerSetup.exe" /u2 /q2
[5/9/2005 15:04:22] Installation succeeded: Autodesk DWF Viewer
[5/9/2005 15:04:22] Installation started: Flash
[5/9/2005 15:04:22] Command = "\\Jan\c\acad
2006\AdminImage\support\flash\Silent Install Flash Player 7 AX.exe" /q
[5/9/2005 15:04:25] [Error: 1] Incorrect function.
[5/9/2005 15:04:25] Installation failed: Flash
[5/9/2005 15:04:25] [Info] Failure is ignored
[5/9/2005 15:04:25] Installation started: AutoCAD 2006
[5/9/2005 15:04:25] Command = msiexec /i "C:\acad
2006\AdminImage\acad.msi" TRANSFORMS="C:\acad 2006\AdminImage\acad 2006.mst"
/Lev "C:\DOCUME~1\JOHN\LOCALS~1\Temp\acad 2006.log" REBOOT=Suppress /qb-
[5/9/2005 15:04:25] [Error: 1619] This installation package could not be
opened. Verify that the package exists and that you can access it, or
contact the application vendor to verify that this is a valid Windows
Installer package.
[5/9/2005 15:04:25] Installation failed: AutoCAD 2006
[5/9/2005 15:04:25] Installation aborted
[5/9/2005 15:04:25] === Installation ended ===
