So i meet the system requirements ( i think? I7, win7, enough ram etc...) , tried to install the 2015 and 2014 version for students and the trial version, but keep getting the same failure screen:
and the log:
2014/4/21:18:58:37 Gangel GANGEL-PC === Setup started on GANGEL-PC by Gangel ===
2014/4/21:18:58:37 Gangel GANGEL-PC Path_Length: 148
2014/4/21:18:58:37 Gangel GANGEL-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_wi_en-US
2014/4/21:18:58:37 Gangel GANGEL-PC Launch
2014/4/21:18:58:37 Gangel GANGEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_wi_en-US_... /SN 900-46748420 /PK 128G1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/21:18:58:37 Gangel GANGEL-PC Current Directory C:\Users\GANGEL~1.GAN\AppData\Local\Temp\_AI295D.tmp
2014/4/21:19:00:37 Gangel GANGEL-PC === Setup ended ===
2014/4/21:18:58:51 Gangel GANGEL-PC === Setup started on GANGEL-PC by Gangel ===
2014/4/21:18:58:51 Gangel GANGEL-PC Path_Length: 148
2014/4/21:18:58:51 Gangel GANGEL-PC Current Directory C:\Users\GANGEL~1.GAN\AppData\Local\Temp\_AI295D.tmp
2014/4/21:18:58:51 Gangel GANGEL-PC Launch
2014/4/21:19:00:08 Gangel GANGEL-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/SETUP_x64...
2014/4/21:19:00:36 Gangel GANGEL-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/SETUP_x64...
2014/4/21:19:00:37 Gangel GANGEL-PC PageOpen LaunchDialog
2014/4/21:19:00:53 Gangel GANGEL-PC PageOpen LicenseDialog
2014/4/21:19:00:53 Gangel GANGEL-PC PageOpen ProductInfoDialog
2014/4/21:19:00:53 Gangel GANGEL-PC PageOpen ProductSelectionDialog2
2014/4/21:19:02:15 Gangel GANGEL-PC PageOpen FullProgressDialog
2014/4/21:19:02:16 Gangel GANGEL-PC Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:19:02:20 Gangel GANGEL-PC Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:19:02:20 Gangel GANGEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\GANGEL~1.GAN\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/21:19:02:51 Gangel GANGEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2014/4/21:19:02:52 Gangel GANGEL-PC Download Play VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:19:02:56 Gangel GANGEL-PC Download Complete VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:19:02:56 Gangel GANGEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/4/21:19:03:17 Gangel GANGEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2014/4/21:19:03:18 Gangel GANGEL-PC Download Play VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:19:03:24 Gangel GANGEL-PC Download Complete VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:19:03:24 Gangel GANGEL-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2014/4/21:19:03:34 Gangel GANGEL-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2014/4/21:19:03:35 Gangel GANGEL-PC Download Play VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:19:03:38 Gangel GANGEL-PC Download Complete VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:19:03:38 Gangel GANGEL-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/21:19:05:26 Gangel GANGEL-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/4/21:19:05:26 Gangel GANGEL-PC Download Play VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:19:05:35 Gangel GANGEL-PC Download Complete VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:19:05:35 Gangel GANGEL-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/4/21:19:06:53 Gangel GANGEL-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/4/21:19:06:54 Gangel GANGEL-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/DIRECTX.t...
2014/4/21:19:07:01 Gangel GANGEL-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/DIRECTX.t...
2014/4/21:19:07:01 Gangel GANGEL-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/21:19:08:43 Gangel GANGEL-PC Install DirectX® Runtime Succeeded
2014/4/21:19:08:44 Gangel GANGEL-PC Download Play CM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/CM.tar.lz...
2014/4/21:19:09:22 Gangel GANGEL-PC Download Complete CM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/CM.tar.lz...
2014/4/21:19:09:23 Gangel GANGEL-PC Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/21:19:10:24 Gangel GANGEL-PC Install Autodesk® Material Library 2015 Succeeded
2014/4/21:19:10:25 Gangel GANGEL-PC Download Play CMILB http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/CMILB.tar...
2014/4/21:19:12:04 Gangel GANGEL-PC Download Complete CMILB http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/CMILB.tar...
2014/4/21:19:12:04 Gangel GANGEL-PC Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/21:19:12:32 Gangel GANGEL-PC Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/4/21:19:12:33 Gangel GANGEL-PC Download Play CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/CMILM.tar...
2014/4/21:19:19:31 Gangel GANGEL-PC Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/CMILM.tar...
2014/4/21:19:19:31 Gangel GANGEL-PC Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/4/21:19:20:12 Gangel GANGEL-PC Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/4/21:19:21:56 Gangel GANGEL-PC Rollback Autodesk® Material Library 2015 Succeeded
2014/4/21:19:21:56 Gangel GANGEL-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/21:19:21:56 Gangel GANGEL-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/4/21:19:21:56 Gangel GANGEL-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/4/21:19:21:56 Gangel GANGEL-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/4/21:19:21:57 Gangel GANGEL-PC Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/21:19:21:57 Gangel GANGEL-PC Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/21:19:22:00 Gangel GANGEL-PC PageOpen InstallCompleteDialog
2014/4/21:19:31:07 Gangel GANGEL-PC === Setup ended ===
2014/4/21:20:36:49 Gangel GANGEL-PC === Setup started on GANGEL-PC by Gangel ===
2014/4/21:20:36:49 Gangel GANGEL-PC Path_Length: 148
2014/4/21:20:36:49 Gangel GANGEL-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_wi_en-US
2014/4/21:20:36:49 Gangel GANGEL-PC Launch
2014/4/21:20:36:49 Gangel GANGEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_wi_en-US_... /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/4/21:20:36:49 Gangel GANGEL-PC Current Directory C:\Users\GANGEL~1.GAN\AppData\Local\Temp\_AI13AD.tmp
2014/4/21:20:36:56 Gangel GANGEL-PC === Setup ended ===
2014/4/21:20:36:52 Gangel GANGEL-PC === Setup started on GANGEL-PC by Gangel ===
2014/4/21:20:36:52 Gangel GANGEL-PC Path_Length: 148
2014/4/21:20:36:52 Gangel GANGEL-PC Current Directory C:\Users\GANGEL~1.GAN\AppData\Local\Temp\_AI13AD.tmp
2014/4/21:20:36:52 Gangel GANGEL-PC Launch
2014/4/21:20:36:55 Gangel GANGEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/SETUP_x64...
2014/4/21:20:36:56 Gangel GANGEL-PC PageOpen LaunchDialog
2014/4/21:20:37:03 Gangel GANGEL-PC PageOpen LicenseDialog
2014/4/21:20:37:03 Gangel GANGEL-PC PageOpen ProductInfoDialog
2014/4/21:20:37:47 Gangel GANGEL-PC PageOpen ProductSelectionDialog2
2014/4/21:20:38:18 Gangel GANGEL-PC PageOpen FullProgressDialog
2014/4/21:20:38:19 Gangel GANGEL-PC Download Play VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:20:38:31 Gangel GANGEL-PC Download Complete VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:20:38:31 Gangel GANGEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\GANGEL~1.GAN\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/4/21:20:38:49 Gangel GANGEL-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/4/21:20:38:50 Gangel GANGEL-PC Download Skipped VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:20:38:50 Gangel GANGEL-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\GANGEL~1.GAN\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/4/21:20:39:07 Gangel GANGEL-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2014/4/21:20:39:08 Gangel GANGEL-PC Download Play VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:20:39:12 Gangel GANGEL-PC Download Complete VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:20:39:12 Gangel GANGEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/4/21:20:39:19 Gangel GANGEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/4/21:20:39:22 Gangel GANGEL-PC Download Skipped VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:20:39:22 Gangel GANGEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/4/21:20:39:32 Gangel GANGEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2014/4/21:20:39:33 Gangel GANGEL-PC Download Skipped VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:20:39:33 Gangel GANGEL-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2014/4/21:20:39:39 Gangel GANGEL-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2014/4/21:20:39:40 Gangel GANGEL-PC Download Play VCREDIST2010SP1X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:20:39:50 Gangel GANGEL-PC Download Complete VCREDIST2010SP1X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:20:39:50 Gangel GANGEL-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart
2014/4/21:20:39:58 Gangel GANGEL-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2014/4/21:20:39:58 Gangel GANGEL-PC Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:20:39:58 Gangel GANGEL-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/4/21:20:40:44 Gangel GANGEL-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/4/21:20:40:44 Gangel GANGEL-PC Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/VCREDIST2...
2014/4/21:20:40:45 Gangel GANGEL-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/4/21:20:41:18 Gangel GANGEL-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/4/21:20:41:19 Gangel GANGEL-PC Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/DIRECTX.t...
2014/4/21:20:41:19 Gangel GANGEL-PC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/4/21:20:42:02 Gangel GANGEL-PC Install DirectX® Runtime Succeeded
2014/4/21:20:42:03 Gangel GANGEL-PC Download Skipped CM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/CM.tar.lz...
2014/4/21:20:42:03 Gangel GANGEL-PC Installing Autodesk® Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/21:20:43:11 Gangel GANGEL-PC Install Autodesk® Material Library 2015 Succeeded
2014/4/21:20:43:11 Gangel GANGEL-PC Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/CMILB.tar...
2014/4/21:20:43:11 Gangel GANGEL-PC Installing Autodesk® Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/4/21:20:43:39 Gangel GANGEL-PC Install Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/4/21:20:43:40 Gangel GANGEL-PC Download Play CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/CMILM.tar...
2014/4/21:20:51:36 Gangel GANGEL-PC Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET4/2015/3DSMAX/WI/{A18D8057-4F8E-4306-A282-9EC2059CA829}/CMILM.tar...
2014/4/21:20:51:36 Gangel GANGEL-PC Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/4/21:20:52:09 Gangel GANGEL-PC Rollback Autodesk® Material Library 2015 - Base Image Library Succeeded
2014/4/21:20:53:04 Gangel GANGEL-PC Rollback Autodesk® Material Library 2015 Succeeded
2014/4/21:20:53:04 Gangel GANGEL-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/4/21:20:53:04 Gangel GANGEL-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2014/4/21:20:53:04 Gangel GANGEL-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2014/4/21:20:53:04 Gangel GANGEL-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/21:20:53:05 Gangel GANGEL-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/4/21:20:53:05 Gangel GANGEL-PC Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/21:20:53:05 Gangel GANGEL-PC Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/4/21:20:53:05 Gangel GANGEL-PC Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/4/21:20:53:05 Gangel GANGEL-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
SO! what do i do? btw, the log for the non-trial version was shorter.
Yes, the problem is an aborted download. This is a somewhat plaguing issue of late.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Good Luck!
