I was trying to find the latest Autodesk IPv4 License Manager for Windows, but the link on the autodesk site gives a 404 error. Anywhere else I can look for the tool or any of the admins who can get this fixed on the site ?
All the best,
Tom
Solved by TravisNave. Go to Solution.
Solved by DarrenP. Go to Solution.
you should be able to use the IPv6 Version without a problem
DarrenP
Darren is right. I have maintained for multiple releases that there are no differences between the versions. Flexera does not provide multiple lmgrd.exe releases for IPv4 and IPv6, so I don't know why Autodesk insists that there is a difference. I have installed both of their versions and neither are different.
In any case, you can download the latest here:
Good Luck!
Okay, thanks for the reply... seems to work...but now I see I have the wrong mac-address in my license file (we're switching servers) must have mixed the network cards up. Will contact our reseller for a new license file.
Thanks again,
Tom
