Installation & Licensing
Autodesk Download Manager
26 REPLIES 26
Message 1 of 27
ccti-reg
18032 Views, 26 Replies
I'm trying to download "Autodesk Education Master Suite English 2013 Win 32/64" throught the download manager and it's not working. When selecting a folder, it either says I need 102 gig more (on a disk with 200gig free and a download size of 42gig), or it accept, create an empty folder and stay there (nothing added to the queue, only a "there is no file" message). If I try to download again, it says "download already in queue".
I then tried browser download, which send me 11 4.0gig file. Problem is, I have 2x part 7 and 0x part 6.
I tried redownloading and looking at all the name, I really receive 2x part 7 and no part 6.
26 REPLIES 26
Message 2 of 27
in reply to: ccti-reg
Same here.
Download manager not working- says not enough space (i have 150gigs free space)
And browser donload misses part 6
I am really not happy with a...
Message 3 of 27
TravisNave
Message 4 of 27
philip.s
Hi ccti-reg and aldur.parts,
Part 6 of the 2013 Education Master Suite can be downloaded here.
Per the 2013 Education Master Suite system requirements, recommended hard disk space is 500 GB.
The Browser Download size is going to represent the file size before extraction and installation, and the Download Now size equates to the size after extraction before installation. In either case the requirement for both is going to be larger than the stated size. The Download Now web manager, checks system space prior to the download to ensure that there is enough room, and hence the download block.
Message 5 of 27
philip.s
in reply to: TravisNave
Thanks Travis!
Message 6 of 27
ccti-reg
Thanks for the reply, now downloading the missing part 6.
Also, part 7 is sent 2 time through the browser.
Thanks again!
Message 7 of 27
Priitl220
I would appreciate if I would not have to download all of them as I only use 5 of them. There should be an option to download them separately.
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Message 8 of 27
philip.s
in reply to: Priitl220
Hello Priitl220,
We're constantly revising the download and installation process to improve the overall experience, with your feedback being a perfect example of a potential driving factor.
I also wanted to attach a link to the following informational article that discusses the space requirements needed for downloading and installing autodesk software.
Message 9 of 27
the smartest post i have found - looking for a workaround concerning the "new & improved download manager"!!!!
Message 10 of 27
ccti-reg
in reply to: philip.s
Yeah it's a pain to download over 50gig when you only need 3 products, but then, I like the fact that I'm able to make multiple deployment package using the same 20gig source. Starting only 1 configuration to install x numbers of product instead of starting x number of configuration (requiring more user input) is a thumbs up.
Message 11 of 27
Well I have never since AutoCAD 2004 seen a "good" deployment for the new Autodesk products - Hence my expectation for “2013” was not that high to begind with - ther is allways some "bugs", licening error, driver stuff and so on...but I had the feeling it was going from "worse" to "not that bad" with 2012 series and that Autodesk was actually trying hard to find a way to help the Administrators for lager installations sites - but adding this "new and improved download manager" and taking away the option for letting me decide - espiaclly when i have a collection of 41 Gb to download and unpack to 160 Gb ... doesn't make sense to me - so a thumbs up for trying Autodesk - maybe 2014 will be the magic number 🙂
Message 12 of 27
I am trying to download Autocad LT 2013 and the Autodesk Download Manager doesn't download the product.  It just hangs and has to be manually shut down.  Is there a direct link to this.  Or what can I do to download this.  I have tried 10 times and nothing.
Tags (1)
Message 13 of 27
philip.s
Here you go femij,
Please utilize the following 48hr timed direct download links.
Click here for AutoCAD LT 2013 32BIT
Click here for AutoCAD LT 2013 64BIT
Click here for AutoCAD LT 2013 for Mac
Message 14 of 27
i dont find the dlm soft ware help me please
Message 15 of 27
philip.s
My apologies for the inconvenience Sahiuddin.
We were experiencing an issue earlier in the day that was preventing the download buttons from displaying correctly. As this has sense been resolved, can you please try again and let us know if you're still not seeing it?
Message 16 of 27
Hi there.
From yesterday morning I'm trying to download my copy of 3D Studio Max 2014 through Autodesk Download Manager but after downloaded 4,23GB it is always trying to go on without success, saying stablighing connection and waiting,  what could be the problem?.
Message 17 of 27
philip.s
Hello Ivar,
It very well could be a firewall issue preventing the download manager from properly connecting. Have you tried opening up ports 80 and 443?
The other workaround would be to utilize an alternative download method, specifically the Browser Download option, which can be found through Matt, our Virtual Assistant.
Message 18 of 27
trying to download revit, why is it that i can only use browser download? i have used it on revit and inventor. they wont install correctly.
Message 19 of 27
philip.s
Hi Chad!
As the Install Now and Download Now options are relatively new (within the last year or 2), they are not available for some of the older version builds. What version of Revit are you downloading? Any specific installation errors?
Message 20 of 27
2012. also im trying to download inventor professional 2012. no errors, just failure to install.
Administrator Productivity
