Installation & Licensing
justin422
776 Views, 2 Replies
Autocad Civil 3D 2009
I had formtted PC & reinstalled Autocad Civil 3D 2009.At the time of rgisteration one message is appearing that Serial No is not Valid.I had used this serail no last two yeares.Now what happend i dont Know.Pls help.
                         Please let me know how to generate Host name & Host ID of the PC.
Regards
Justin Joseph
2 REPLIES 2
hashim.mundol
in reply to: justin422
Please use one of the manual activation method mentioned here
http://usa.autodesk.com/adsk/servlet/item?linkID=9241177&id=5584421&siteID=123112
if you have network license hostname and hostid can be found using the following method
http://wikihelp.autodesk.com/Inventor/enu/2011/Help/130InstallInstructions/200LicensingGuide/1021_Ne...
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
TravisNave
Your serial number may not be valid for a few reasons.  If your serial is for a network verison and you have installed as stand-alone, then your serial number will be invalid for activation.  You cannot activate a network seat as stand-alone.
You will need to install the NLM and get a new LIC file, if you were hosting your NLM locally.  If it was hosted on another machine, then simply reinstall as a network seat and point the client to the hostname of the NLM server.
Please call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 2 > Network
You will need to provide your serial number and ethernet ID of the new license server.
www.licenseparser.com > This will break down your current license file into plain english and you will find the serial number there.
You should download the lastest server tools here:
www.autodesk.com/nlm-ipv4-windows
www.autodesk.com/nlm-ipv6-windows
If your 2009 was under Subscription and was upgraded to a newer version and your Subscription has expired, then your old serial number will be invalid.  Any upgrade or crossgrade without Subscription will also invalidate your serial number.
Autodesk Forums:
Administrator Productivity
