I installed AutoCAD 2013 on a Windows 7 64 bit machine. The program runs, but then when you end the porgram it gives a Unhandled exception error.
This is a stock standard Dell Precison with a Quadro Card. I tried the program on a ASUS motherboard based computer again running Windows 7 and got a similar error at startup.
Any ideas welcome.
JMN
Maybe it is failing trying to close down the communication center or the login connection to Subscription? Does it do it when you launch and close while offline? Does it do it when logged in as another user with local admin rights?
